what is a goo fuel system
Old Oct 28, 2005 | 10:03 PM
big juan's Avatar
Default what is a goo fuel system
whats up yall i have a question a want to build a 650 whp car and i want to know what would be a good fuel system
what kind of
fuel pump
fuel pressure regulator
fuel rail
the injectors are 1000cc
please help
Old Oct 28, 2005 | 10:13 PM
2k.civic.si's Avatar
Default Re: what is a goo fuel system (big juan)
go here http://www.trevtec.com tell them artieman sent you =P they will take care of you
Old Oct 29, 2005 | 05:09 AM
B18 CYA's Avatar
for 650whp i think u'll need bigger than 1000cc injectors
Old Oct 29, 2005 | 05:40 AM
BlueShadow's Avatar
I've been readng up on fuel systems the lasat couple of weeks. I used to think that RC injectors and Walbro fuel pumps were pretty good. Until some people talked about how they or someone they knew had problems with those setups. But based on what I've learned here is what I would recommend:
FUEL PUMP
-Walbro 255lph fuel pump with upgraded wiring
-Aeromotive A1000--with this I think you'll need to do a gravity feed/sump setup (not sure what the technical term is)
FPR
-Aeromotive or SX (both are the same from what I hear)
FUEL RAIL
-Aeromotive fuel rail-Aeromotive's application guide says it's for a Integra GSR, but I think you can use it for other B series motors
-Golden Eagle
FUEL INJECTORS
-Precision
-Siemens Deka
One thing you should be aware of is the above setups wont always be plug and play. if you have a remote mounted or bypass FPR like the Aeromotive 13109 you'll have to make sure you have all your lines and fittings. Check out the link below to give you an idea of what the install would be like.
https://honda-tech.com/zerothread?id=655371
Old Oct 29, 2005 | 06:59 AM
B18 CYA's Avatar
yep i got the a1000 fuel pump and i love it. kinda noisy but thats cuz i didnt seal it under my car properly and my siemens 700cc injectors are doin well also
LS/V-T
Nov 30, 2010 02:09 PM
Joel_MN
Aug 17, 2003 11:59 AM
spcmotorsports
Oct 9, 2002 05:24 AM
Brian_92GSR
Oct 25, 2001 11:27 AM
