LS => Delsol swap trouble
Old Oct 28, 2005 | 06:50 PM
Orangedragone's Avatar
Default LS => Delsol swap trouble
Okay, I've swapped an LS into a DelSol. Really i have but only a few obstacles but here are some of my problems.
1)Mounting the rear. Specifically the Lbracket. Now a GSR bracket won't fit and neither will the old sohc bracket. Altho Im told that an Lbracket off a b16 should work?
2)Shift linkages. Integra shift linkages won't work, and neither will the sohc links. I'm told that the only shiftlinkage that WILL fit is a DOHC delsol shift linkage. If this is true i'll probably put an order for it at honda soon.
3)With everything in except for the previously stated when i tried starting my car when i turn the key to on the car just starts cranking. I don't even crank the key over and the starter just starts cranking over. I don't believe this is normal, correct?
Now bare with me this is my first swap. Altho i did some homework and made sure that everything was OBD1. I had some doubts with the harness but i was told that you could run off of an automatic--which is what it's wired up with as of now.
Any advice on any of the 3 problems would be appreciated, altho the 3rd is my biggest worry. i DREAD electrical problems.
Thanks
Old Oct 28, 2005 | 07:18 PM
.Beaver's Avatar
Bloody Beaver
Default Re: LS => Delsol swap trouble (Orangedragone)
#1-2 you need everything for a DOHC Del Sol...
#3 uhh... have no clue!
Old Oct 28, 2005 | 07:26 PM
pennies_hatchie's Avatar
Default Re: LS => Delsol swap trouble (Leeroy)
1. any dc2 and delsol vtec rear L bracket will work
2. del sol vtec only shift linkage
3. use a manual wire harness. there are more plugs on a auto then a manual. also check ignition (by the key) maybe its loose so when you try turning it, it goes to the next click already.
Old Oct 28, 2005 | 07:46 PM
Default Re: LS => Delsol swap trouble (pennies_hatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennies_hatchie &raquo;</TD></TR><TR><TD CLASS="quote">
3. use a manual wire harness. there are more plugs on a auto then a manual. </TD></TR></TABLE>
I did have a 5 speed harness but the plugs for the fuel injectors didn't match. And while searching for a replacement harness i was told that i COULD run off the automatic harness. (?)
Old Oct 29, 2005 | 06:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennies_hatchie &raquo;</TD></TR><TR><TD CLASS="quote"> also check ignition (by the key) maybe its loose so when you try turning it, it goes to the next click already.</TD></TR></TABLE>
I just checked. And the ignition isn't lose. I still get two clicks and then a crank. But it still cranks after the 2nd click
Old Oct 29, 2005 | 07:15 AM
90civichb's Avatar
I don't think the automatic harness is your issue, the only difference between the two is a few sensors on the tranny, and a possible issue with reverse lights......
I have an auto wire harness in my civic from an auto to manual swap, and it works fine.
Old Oct 29, 2005 | 07:43 AM
brizjuan's Avatar
b20 swapped del sol..... used stock OBD1 del sol harness.... worked perfect... and dont not use the 5 speed harness u had just cause of the injector clips... all u need is to go to a junkyard...find wtvr obd injector clips u need... cut the two wires and rewire them up to ur existing harness....
Old Oct 29, 2005 | 08:06 AM
hatchi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennies_hatchie &raquo;</TD></TR><TR><TD CLASS="quote">1. any dc2 and delsol vtec rear L bracket will work
3. use a manual wire harness. there are more plugs on a auto then a manual. also check ignition (by the key) maybe its loose so when you try turning it, it goes to the next click already.</TD></TR></TABLE>
use your original harness and cut and solder the injector harness from the auto harness to the original one.
h22accord101
16
Jan 16, 2011 12:59 PM
hbombhondacrew
Jul 6, 2008 11:29 AM
highflyinhonda
Jun 5, 2007 05:36 PM
88EFRacer
Apr 26, 2007 08:19 PM
Tjames8864
Jan 10, 2007 07:07 PM
