b20z into 94 integra wiring ?'s (search is Down)
I'm in the middle of trying to swap an obd2 98b20z into my friend's 94 teg.we are using an obd1 LS ecu. due to money problems, we are keeping the b20 intake manifold,injectors,alternator and distributor.So far, i have everything assembled, but i am at a standstill at the wiring.
I am using a 93civicDX engine harness. I can see that the injector plugs, distributor plugs, and the alternator plugs are different.
Can i just snip the injector plugs off the b20 harness and wire them into the DX harness?
same way for the distributor and alternator. can I get away with simply changing the plugs? i can tell the distributor wiring will be a little complex due to the DX harness having two distributor plugs.
can anyone give me a quick answer?
thanks in advance
thanks in advance
you need to keep the injectors/distributor/wire harness from the original 94 OBD1 integra.
the OBD2 harness and injectors wont work........
Honda_Tengoku
Sep 12, 2004 02:08 PM
