SPARK UNDER HOOD AND NOW NO JUICE.....HELLP
Well the search server is down so im gonna ask this before searching... I was workin under the hood the other day fixin an oil leak on my oil feed line and a loose wire from my oil temp sensor that was cut hit my starter i guess and had a pretty decent sized spark... so i disconnected my battery... the next day i finished up wut i had to fix and hooked up my battery again... went to start it and nothing... no turn over... no lights... not even my radio... cars completely dead... tested the battery for juice and it has plenty of power.. So i obvious blew a main fuse somewhere.. I checked all the little guys under the hood and there all ok... now though big ones that are like boxes I have no idea wut im lookin at or wuts wut... the diagram sheet is lost... This is a 95 b20 turbo del sol by the way... Any ideas... or can someone hook me up with a diagram of my fuse box under the hood... once i figure out which ones are which im gonna need a step by step way to check em
samirsamir
86
Jan 30, 2016 04:10 PM
J.nguyen
Dec 2, 2006 11:05 PM
JdM DiNg DoNg
Feb 19, 2004 02:37 PM
.... It was the 80A fuse under the hood... problem solved...
