Which cams are better for forced induction if I want to stay OEM.
wait...if i work my b18 motor at lets say 7psi giving me 300whp wont CTR cams give me more gains than GSR cams??? why would they only give me more if i go 25psi having 500whp???whats the difference?
i've seen GSR cams make 500whp, but the CTR cams have alot of overlap, they may give some power to 300whp cars, but they also have alot of overlap, so i guess if you throw on some cam gears then you are good to go. But i wouldn't recommend CTR cams to a normal 250-300whp car, GSRs will pull hard to 8800rpms all day long.
CTRs will make more power on the same setup.
If you have no cams yet, then get type r for sure.
If you have GSR already, then your power goals should dictate whether or not you want/need to upgrade them.
thats the problem though with H-t right now. Everything has been covered. Im just banking that once K-series come down in price a whole new section of topics and research begins like H-t used to be.
What kind of manifold?
If it's a log... with high backpressure... go with a shorter-duration higher-lift. Otherwise if it's tubular, up the duration because it will run at a lower TIP so you will get less reversion and make more power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene »</TD></TR><TR><TD CLASS="quote">What kind of manifold?
If it's a log... with high backpressure... go with a shorter-duration higher-lift. Otherwise if it's tubular, up the duration because it will run at a lower TIP so you will get less reversion and make more power. </TD></TR></TABLE>
finally a GOOD answer
streetlights
Dec 24, 2004 04:24 PM
