5 Lug conversion on a EK
Old Oct 28, 2005 | 09:03 AM
Jdm_honda_ek9's Avatar
Default 5 Lug conversion on a EK
I'm sure this has been posted before but I didn't see any other posts. I'm about to buy a CTR 5 lug conversion and I was wondering how involved the installation is. And if there is any site I can go to for help, I'm sure I can figure out the suspension part it. It's more the running the rear brake lines, e-brake, proportioning valve and master cylinder. Anything will help, thanks
Old Oct 28, 2005 | 09:39 AM
RedEK9's Avatar
Default Re: 5 Lug conversion on a EK (Jdm_honda_ek9)
Believe me when I tell you this... It's pretty straight forward. Just buy the SI brake lines and prop valve and your set. Everything bolts straight on, the most tideous part of it all was installing the prop valve.
And make sure you read the L and the R on the calipers, they do bolt on backwards and thats what kept my car out of commission for like a month and a half. Make sure you have 2 bottles of dot3 brake fluid just in case. It's perfectly ok to recycle the fluid once you crack the bleeder, just get a small hose to put on the valve and lead it back in to the bottle.
Let me know if you need some help
Old Oct 28, 2005 | 09:48 AM
Default Re: 5 Lug conversion on a EK (RedEK9)
Thank you that does seem easier then I thought, I'm in iraq right now but I come home in about 3 months. So that is when I'll be doing the conversion. Thank you and I'll hit you up if I get stuck
Old Oct 28, 2005 | 11:30 AM
Kouki-EK9's Avatar
Yeah, it's not hard, just a bit tedious. I did mine all by myself last year at the age of 17.
Old Oct 28, 2005 | 11:32 AM
Kouki-EK9's Avatar
I just read that we have the same motor, sweet.
Old Oct 28, 2005 | 02:25 PM
RedEK9's Avatar
Default Re: 5 Lug conversion on a EK (Kouki-EK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm_honda_ek9 &raquo;</TD></TR><TR><TD CLASS="quote">Thank you that does seem easier then I thought, I'm in iraq right now but I come home in about 3 months. So that is when I'll be doing the conversion. Thank you and I'll hit you up if I get stuck</TD></TR></TABLE>
Prolly told you this before, but..... stay safe. Hit me up when you get back, i'll be more than happy to help
lil_rob
Suspension & Brakes
Jul 10, 2010 05:50 AM
orientalgunz_00
Jan 31, 2006 11:19 PM
jimmhatch
Jun 25, 2005 06:31 AM
RedEK9
Suspension & Brakes
21
Feb 8, 2005 05:28 PM
1QWKGS
Jul 13, 2003 05:06 AM
