high hp, high boost, head gasket?
Old Oct 27, 2005 | 10:51 PM
whoneedzvtec's Avatar
Default high hp, high boost, head gasket?
what are u guys with the high hp and high boost (27+psi) motors using for head gaskets. also what torque r u using on ur head bolts. and is ur block o-ringed. thanks guys just trying to get a few ideas.
Old Oct 27, 2005 | 11:09 PM
Group Tenacity's Avatar
Default Re: high hp, high boost, head gasket? (dc2ls-t)
We use oem headgaskets on our cars... I couldnt tell you the answers to the other questions because i dont know them...
Mike...
Old Oct 28, 2005 | 12:16 AM
HYBRID_H@TCH's Avatar
Default Re: high hp, high boost, head gasket? (Group Tenacity)
I use a cometic HG and torque the head studs to 65 lbs..
Old Oct 28, 2005 | 12:44 AM
Hybrid_Coupe's Avatar
Default Re: high hp, high boost, head gasket? (99Hybrid_Hatch)
yep same here...no h/g problems yet...
Old Oct 28, 2005 | 01:23 AM
itr_18's Avatar
Default Re: high hp, high boost, head gasket? (Hybrid_Coupe)
I used Cometic on 25psi. Now Im going to boost 30+ and also on Cometic.
Old Oct 28, 2005 | 04:28 AM
DaveF's Avatar
Default Re: high hp, high boost, head gasket? (itr_18)
we are running Golden Eagle mfg. HD blocks in our cars with o-ring groove(copper 18guage o-rings) headstud torque to 70-75ft/lbs... we made a little over 800 and have no gasket problems thus far.
Old Oct 28, 2005 | 09:47 AM
Default Re: high hp, high boost, head gasket? (Dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">we are running Golden Eagle mfg. HD blocks in our cars with o-ring groove(copper 18guage o-rings) headstud torque to 70-75ft/lbs... we made a little over 800 and have no gasket problems thus far. </TD></TR></TABLE>
and ur also using the copper head gasket right?
Old Oct 28, 2005 | 12:44 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2ls-t &raquo;</TD></TR><TR><TD CLASS="quote">
and ur also using the copper head gasket right?</TD></TR></TABLE>
stock overbore GE headgasket, with copper spray.
Old Oct 29, 2005 | 08:20 AM
rainmanef's Avatar
Seems like copper a lot...j/k
Old Oct 29, 2005 | 09:51 AM
johnzm's Avatar
Default Re: high hp, high boost, head gasket? (rainmanef)
has anyone ever BLOWN their headgasket? i swear i havent seen any B series every blow one!!!
Old Oct 29, 2005 | 01:54 PM
.john.'s Avatar
Default Re: high hp, high boost, head gasket? (johnzm)
i think its more common to "lift" the head and leak a little boost into the water jackets rather than blowing between cylinders.
Old Oct 29, 2005 | 10:44 PM
GT40eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm &raquo;</TD></TR><TR><TD CLASS="quote">has anyone ever BLOWN their headgasket? i swear i havent seen any B series every blow one!!!</TD></TR></TABLE>
i blew my headgasket. i had 84mm cometic and 2-step to long on pump gas
got a new and running 28psi with no problems.
Old Oct 29, 2005 | 11:25 PM
JDogg's Avatar
Default Re: high hp, high boost, head gasket? (turboDc2)
we run cometic on everything... never have a problem
Old Oct 30, 2005 | 01:12 AM
tony1's Avatar
Oh, they can blow, trust me! lol
Old Oct 30, 2005 | 04:54 AM
HR-1320's Avatar
Default Re: high hp, high boost, head gasket? (tony1)
Have you been having issues when you start to run 50-60lbs of boost.
Old Oct 30, 2005 | 07:07 AM
Drag-Accord's Avatar
Default Re: high hp, high boost, head gasket? (2.0Coupe)
Damn b-series!!!
With my H-series at stock bore running cometic i blew 2 this year. Well not really blew, but like mr. john said it just leaked boost into water jackets. I'm running 30lbs of boost and torqued head studs to 105lbs. This is an H22 though
I think i'm going to try an oem gasket w/copper spray. See if that works.
Old Oct 30, 2005 | 10:03 AM
SOHCboost's Avatar
OEM BITCHES
Old Oct 30, 2005 | 10:56 AM
Default Re: high hp, high boost, head gasket? (Drag-Accord)
what is this copper spray stuff u guys r talkin about? i've never heard of it.
Old Oct 30, 2005 | 11:00 AM
DaveF's Avatar
spray a few good coats on your stock headgasket. i spray like 3 thick coats on my gaskets, then let the copper spray dry, then install.
http://www.jegs.com/webapp/wcs...22441
Old Oct 30, 2005 | 01:11 PM
thats looks like some cool stuff. what exactly does it do to help though?
Old Oct 30, 2005 | 01:13 PM
woops. nevermind. didnt see the link below. i understand now. thanks for the info
grand champ
Jan 20, 2010 12:57 PM
White_EK49
Nov 6, 2005 10:22 PM
D-meet07
Nov 4, 2004 06:29 PM
b00stedbyFastrax
Sep 14, 2002 09:08 PM
InfamousRS
Dec 15, 2001 06:02 PM
