Need some ideas: b18c1 turbo
Old Oct 27, 2005 | 02:51 PM
tomu06's Avatar
Default Need some ideas: b18c1 turbo
Hey i bought a 95 Vx, w/ the gsr block in need of some work. it needs to be resleeved.. i was told by some that running a stock internal b18c1 w/ a good tune would be fine.. others tell me that i should bore it out to a 2.0, and put after market pistons in it, to get like 9-0 compression. The car came with a hondata p28, and a stock p72.. which one should i run w/ the turbo..? anything helps, and if you need more info i will be glad to give ty
Old Oct 27, 2005 | 04:42 PM
Rikter's Avatar
Run the hondata and take it to a dyno to get it tuned for your setup when you figure out what that is and the car is running.
-Rik
Old Oct 27, 2005 | 04:51 PM
Da K00l Aid Mayun's Avatar
Default Re: (Rikter)
I am running an 84mm block with 8/8:1 comp pistons in it and AEBS sleeves
Old Oct 28, 2005 | 12:37 AM
BlueShadow's Avatar
Default Re: Need some ideas: b18c1 turbo (tomu06)
If you are on a tight budget then you can just leave it at stock bore size and upgrade just the pistons and rods. You'd have to get the cylinders honed but if thye aren't too damaged or anything, then you can leave it with stock cylinders. Sleeving the motor adds about another $800-$1000 to the cost of the motor build up. The extra displacement will allow you to make a little more power and TQ. So if you can afford it, I say go for it.
Old Oct 28, 2005 | 04:35 AM
murtnabila's Avatar
Default Re: Need some ideas: b18c1 turbo (BlueShadow)
He's sayin the block already is in the need to be sleeved for whatever reason.
I would bore .02 over and get like 9:1 pistons.
BoOstedN1ck
Aug 8, 2009 05:22 AM
turbochargeb18c
May 21, 2005 06:09 AM
MugenRacerX
Nov 15, 2004 07:29 PM
MastahB16
Nov 13, 2004 02:32 AM
TurboBumblBee
Jan 16, 2004 05:14 AM
