Massive vibration during acceleration and sterring issue
Old Oct 27, 2005 | 02:41 PM
LSegHatchy's Avatar
Default Massive vibration during acceleration and sterring issue
i searched and everyone says cv joints just replaced them all in perfect condition ... what else could it be ...
When i accell i feel vibration ... but only in the steering ... liek the harder i accel the worse it is ... and then @ 50 or higher in fifth gear there is a continuos vibration occurring... just the other day i found out that i have a sterring problem ... that either the inner or outer tir rods are shot cuz i cant lock the sterring wheel and the pass wheel will still move about 1/4 inch in either direction..
Any suggestions with this issue will be greatly appreciated
Old Oct 27, 2005 | 02:59 PM
dogbiscuit's Avatar
my car used to do this, it was Heavily warped and crappy dry rotted tires to fault. try getting your tires rotated and see if the performance changes.
if it does i'd go ahead and buy new tires
Old Oct 27, 2005 | 03:19 PM
LSegHatchy's Avatar
Default Re: (dogbiscuit)
nope not tires either ... just replaced them ..... and had the balancing done about a month ago ...
i noticed the vibration during a long trip from delaware to englishtown raceway
Old Oct 27, 2005 | 03:22 PM
si0385.'s Avatar
Default Re: (LSegHatchy)
i would start with replacing that tie rod end... did it feel loose when u moved the p/s tire by hand?
Old Oct 27, 2005 | 03:28 PM
LSegHatchy's Avatar
Default Re: (turbodreamz0385)
the tire was blted down firmly ... it wouldn't move up and down but would move about a 1/4 inch in either directiong left to right
Old Oct 27, 2005 | 03:31 PM
si0385.'s Avatar
check it again and have someone look at the tie rod and see if they can see the tie rod moving when u move the wheel
Old Oct 27, 2005 | 03:57 PM
LSegHatchy's Avatar
my boy looked at it already he said that when i moved the wheel the tie rod looked like it was jumping ... so i am almost 100% sure the tie rod is ******* toast....
Old Oct 27, 2005 | 04:01 PM
si0385.'s Avatar
Default Re: Massive vibration during acceleration and sterring issue (LSegHatchy)
than i would bet a glass of milk and a cookie that is you're vibration
Old Oct 28, 2005 | 07:25 AM
dogbiscuit's Avatar
try jacking up the car and grabbing your wheels individually and see if they have any play. maybe berings or something, try that
Old Oct 28, 2005 | 07:52 AM
gunnis's Avatar
Is there a link for inner\outer tie rod replacement around?
Old Oct 28, 2005 | 08:02 AM
b204dr's Avatar
could be
warped rotors
tie rod
bent rim( some times not noticable at all to a naked eye )
etc
Old Oct 28, 2005 | 08:09 AM
snatch's Avatar
Default Re: (b204dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunnis &raquo;</TD></TR><TR><TD CLASS="quote">Is there a link for inner\outer tie rod replacement around?</TD></TR></TABLE>
One with pictures, one with a better description.
https://honda-tech.com/zerothread?id=490117
https://honda-tech.com/zerothread?id=1031874
Easy as pie. Did mine in about 30 minutes last weekend.
Taxpayer779
Nov 30, 2018 11:01 AM
BrayzieEF9
19
Jun 30, 2010 02:42 PM
silentwest
May 27, 2008 07:53 PM
Thirty-Nine
Jan 20, 2004 08:12 PM
civic chic
11
Jan 7, 2003 03:00 PM
