Problem with JDM parts... Help Please
i've got a couple of problems with my car
<U>1. JDM ITR non-hid headlights</U>
There's something wrong with my passenger headlight because i can't adjust them. They're pointed too far down. And i know the ***** i have to turn to adjust them, but it doesn't seem to make the beam go up or down. How can i fix this?? This is how i got the headlights, so i didnt do anything to em.
And another thing is, does anyone have experience in taking these headlights apart? I want to clean the inside of the headlight and reseal it myself because i think there might be a leak somewhere. Cuz when it rained a cpl of days ago, it fogged up a little bit
<U>2. JDM ITR Climate Control </U>
One of the vents is broken and i was wondering how i could go about fixing it. Is there even a way to fix it??
Any suggestions welcomed. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N »</TD></TR><TR><TD CLASS="quote">
chris - who wonders if the climate created by this 'jdm' control is better and makes you happier than the usdm counterpart
Me too.
</TD></TR></TABLE>Me too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N »</TD></TR><TR><TD CLASS="quote">chris - who wonders if the climate created by this 'jdm' control is better and makes you happier than the usdm counterpart
The 'JDM' climate control is far superior to its USDM counterpart due to the fact that the 'JDM' unit produces cooler ambient air under maximum acceleration.
BTW: To the original poster in the thread...that appears to be a USDM unit and I'm bet you can buy a climate control anywhere and switch out the vents not positive they are removable though......
</TD></TR></TABLE>The 'JDM' climate control is far superior to its USDM counterpart due to the fact that the 'JDM' unit produces cooler ambient air under maximum acceleration.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N »</TD></TR><TR><TD CLASS="quote">does jdm climate control ..... nevermind.
As put in another thread....It's built by Jasmanians....
</TD></TR></TABLE>As put in another thread....It's built by Jasmanians....
That's a USDM climate control unit.
On the JDM unit the hazard button is on the right, and the rear defroster on the left. The buttons could have been switched, but that's the only difference between the JDM and USDM climate controls.
In JDM'ville they drive on the "other side" of the road, and therefore the headlight adjustments aren't optimal for us here in the states with LHD, and where we drive on the <U>right hand side</U> of the road.
As to what to do about it ... possibly some washers on/at the attachment points of the headlight assy. to the chassis.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed »</TD></TR><TR><TD CLASS="quote">As to what to do about it ... possibly some washers on/at the attachment points of the headlight assy. to the chassis. </TD></TR></TABLE>
Good call, Ed.
Line up square to a wall at night, and apply engineering fluid liberally until you come up with a good pattern.
Good call, Ed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid »</TD></TR><TR><TD CLASS="quote">That's a USDM climate control unit.
On the JDM unit the hazard button is on the right, and the rear defroster on the left. The buttons could have been switched, but that's the only difference between the JDM and USDM climate controls.</TD></TR></TABLE>
I switched them around
Thanks
Thanks
the front end i got from this shop in Corona... and as far as the climate control, i got it from the Hmotors warehouse and i didn't notice the damaged vent till way way later
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RevHard »</TD></TR><TR><TD CLASS="quote">The 'JDM' climate control is far superior to its USDM counterpart due to the fact that the 'JDM' unit produces cooler ambient air under maximum acceleration.
Heck yea!... i put that baby on my car over the summer and i didn't even need AC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RevHard »</TD></TR><TR><TD CLASS="quote">BTW: To the original poster in the thread...that appears to be a USDM unit and I'm bet you can buy a climate control anywhere and switch out the vents not positive they are removable though......</TD></TR></TABLE>
Yea i thought about just using one of my stock vents and switching it out. But i couldnt really figure out how to do it, i wasn't sure if there was a trick to it
actually....those vent blades are removeable. I've done it on one from a junkyard and swapped it over to a USDM A/C unit shortly before buying the faux cf stuff myself
Its a pain in the *** and it takes very steady and careful hands to do. But rather than to go through that and take the risk of scratching it up pretty good.....I'd go and ask the seller of the item what they will do for you first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naruto »</TD></TR><TR><TD CLASS="quote"> But rather than to go through that and take the risk of scratching it up pretty good.....I'd go and ask the seller of the item what they will do for you first. </TD></TR></TABLE>
I'll try that. I dont think they'll do anything. But worth a try
Dude!
Duh... the JDM climate control = Celsius... everybody who knows anything knows that Celsius is like ten times better than Fahrenheit!!!
on you!!!
</TD></TR></TABLE>Dude!
on you!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ff_terror »</TD></TR><TR><TD CLASS="quote">Duh... the JDM climate control = Celsius... everybody who knows anything knows that Celsius is like ten times better than Fahrenheit!!! </TD></TR></TABLE>
Yea... the Metric System owns all... haha
im a moron and got oissed at my girl , needless to say my ac vent looks exacly like that one , im just afraid of what acura will say it costs to fix
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00-501itrspec »</TD></TR><TR><TD CLASS="quote">im a moron and got oissed at my girl , needless to say my ac vent looks exacly like that one , im just afraid of what acura will say it costs to fix</TD></TR></TABLE>
be very afraid.....they'll probably say that they'll replace it. If they do...then....
according to https://www.acuraautomotiveparts.org/
for the type R, that part itself ( not including the buttons n switches ) cost about $216.23 list price...but they will sell it for $183.80 plus shipping online. If you look at Integra, 2001, 3dr Type R, Instrument Panel Garnish, and illustration number 24. You can expect it to be around the same anywhere else you go.
Drinker
