LS swap ===> harness problem
Old Oct 27, 2005 | 07:41 AM
Orangedragone's Avatar
Default LS swap ===> harness problem
Alright, i asked this question on the EG/Delsol forum, but i suppose it's more of an integra question?
Swapping an LS into my Delsol. Motor came off an automatic and i was told i CAN't run off of those and that i needed the 5 speed harnesses. So i got them. BUT the plugs on the 5 speed harness dont' match on the fuel rail/fuel injectors.
Any answers on how to over come this? 95 ls IS obd1 correct? could i just get an throttle body from a 5 speed? Could i splice wires?
Old Oct 27, 2005 | 07:43 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: LS swap ===> harness problem (Orangedragone)
My memory gets the best of me on the other issues, but you CAN use an automatic harness for your application. Are you also using the automatic ECU?
Old Oct 27, 2005 | 07:44 AM
Default Re: LS swap ===> harness problem (shamoo)
Nope, using a p75.
Old Oct 27, 2005 | 08:04 AM
LL2009's Avatar
i not sure but i think you can used your delsol harnes.
hYbRid_Eg6
Apr 16, 2009 09:44 PM
ryanevansoh
Oct 5, 2008 05:47 PM
westauto
May 8, 2008 11:58 AM
B16A3Civic*Eg
May 5, 2006 08:26 PM
