where can i find my pcv valve?
Old Oct 27, 2005 | 02:24 AM
lv6l's Avatar
Default where can i find my pcv valve?
where can i find my pcv valve in a 94 hatch cx? and how do i remove it to clean or change. i'm having horrible gas milage. i've tried many things. could the pcv valve be one of them??
Old Oct 27, 2005 | 02:30 AM
ek_99_SiR's Avatar
Default Re: where can i find my pcv valve? (lv6l)
in the intake mani..
Old Oct 27, 2005 | 02:31 AM
LL2009's Avatar
you can find it any where pepboys, autozone
to remove it just pull it out no science to it .
Old Oct 27, 2005 | 02:34 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: where can i find my pcv valve? (LLEO245)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LLEO245 &raquo;</TD></TR><TR><TD CLASS="quote">you can find it any where pepboys, autozone
to remove it just pull it out no science to it . </TD></TR></TABLE>
I think he meant the location... if i remember right its between the intake manifold runners. Should be a hose that connects to the intake manifold itself.
Old Oct 27, 2005 | 02:42 AM
lv6l's Avatar
where is the manifold runners. is it located under the manifold or to the right or left if i'm standing in front of the car.
Old Oct 27, 2005 | 05:20 AM
mc's Avatar
mc
Default Re: (lv6l)
Old Oct 27, 2005 | 07:43 AM
EGDC2CIVIC's Avatar
Default Re: (mc)
#6 is the pcv valve
Modified by EGDC2CIVIC at 3:51 PM 10/27/2005
Old Oct 27, 2005 | 09:23 AM
.Kevin.'s Avatar
Default Re: (EGDC2CIVIC)
if i may ask how the heck does that cause bad gas millage?
Old Oct 27, 2005 | 09:34 AM
Luserkid's Avatar
Default Re: (Slow_CvC99)
It doesnt. But it is something you want to change with your oil so it doesnt dirt your oil.
Old Oct 27, 2005 | 12:42 PM
alotawatts's Avatar
From the above diagram I'd have to say # 2 is the PCV valve. #6 looks like one also ???? wtf
If these valves plug up enough it can cause rough idle, running, = effects gas milage
Old Oct 27, 2005 | 01:14 PM
lv6l's Avatar
oh, the PCV valve does not effect my gas milage?
Old Oct 27, 2005 | 01:15 PM
lv6l's Avatar
can it cuase bad idle. i'm having an idle problem too.
Old Oct 27, 2005 | 01:19 PM
civiccoupe94's Avatar
Just change it. enough said, its only 2 bucks
Old Oct 27, 2005 | 01:53 PM
lv6l's Avatar
ok. as alotawatts said. he doesn't know weather #2 or #6 in the picture is the PCV. which one is it?
Old Oct 27, 2005 | 01:58 PM
mwieczorek43's Avatar
Default Re: (lv6l)
Its #6. At least my PCV looks just like #6...
#2 does look like a straight PCV though.... is there two on that motor?
Old Oct 27, 2005 | 02:33 PM
alotawatts's Avatar
Default Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l &raquo;</TD></TR><TR><TD CLASS="quote">ok. as alotawatts said. he doesn't know weather #2 or #6 in the picture is the PCV. which one is it?</TD></TR></TABLE>
No..... I said # 2 is the PCV valve. It's location with a rubber grommet into a breather box is the norm. # 6 is in question since I have never seen two inline PCV's on a vehicle. And if you don't want to believe me about rough idle and running thats fine too !
Did a look-up. # 2 is PCV Valve - # 6 is a PVC Joint. Maybe you can light it and smoke it ? Someone here will know if and why there are two of them.
next ?
Modified by alotawatts at 3:45 PM 10/27/2005
Old Oct 27, 2005 | 03:12 PM
.Ry's Avatar
.Ry
Default Re: (alotawatts)
Get under your car and take off the oil filter. Look above where it was and there is a black box. On the left side the box there will a black house connected to it. Take a long flathead screwdriver, and pry the what looks like a grommet. Once its free go up top and pull the hose through the Intake Manifold. Now you can see what you have. Could be an inline, but im thinkin its acually at the end of the line. Once you get the new one in, feed the hose back down, and plug it back in. Finish the oil change and start her up. Check for leaks as always and your done.
Old Jan 4, 2008 | 04:15 PM
CBR_15's Avatar
Default Re: (.Ry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Ry &raquo;</TD></TR><TR><TD CLASS="quote">Get under your car and take off the oil filter. Look above where it was and there is a black box. On the left side the box there will a black house connected to it. Take a long flathead screwdriver, and pry the what looks like a grommet. Once its free go up top and pull the hose through the Intake Manifold. Now you can see what you have. Could be an inline, but im thinkin its acually at the end of the line. Once you get the new one in, feed the hose back down, and plug it back in. Finish the oil change and start her up. Check for leaks as always and your done.</TD></TR></TABLE>
can you change it without doing an oil change? or will oil start shooting out?
Old Apr 14, 2008 | 11:18 PM
oldindustryrevolutionist's Avatar
From: jacksonville, florida, united states of america
Default Re: (CBR_15)
IF crud is found at the top part of the black hose where the pcv inserts, how does one remove the crud and how can the black box be checked for damage or does it also need removal.
Old Apr 15, 2008 | 02:50 AM
b16a4's Avatar
Default Re: (oldindustryrevolutionist)
i wouldnt advise changing it, if you dont know what it is.
its in a difficult spot to change.
SnailSlowDelSol
Feb 21, 2016 09:26 PM
Eighty-Nyne
Jun 26, 2009 06:45 PM
Mugen_DC2R
Mar 4, 2007 09:36 AM
vince
Mar 7, 2005 12:56 PM
Louie_EM1
Mar 2, 2004 08:15 AM
