how do i know if my codes are clear
Old Oct 26, 2005 | 11:45 PM
lv6l's Avatar
Default how do i know if my codes are clear
i check my code in my 94 civic cx. i put in a paper clip and jump the two wires near the ecu. i turn on my key and they CEL does not blink or anything. how can i tell if my car has no problems?
Old Oct 26, 2005 | 11:46 PM
JDMlyfestyle's Avatar
if your CEL does not flash then that means you have no codes
^^^^^ Thank you Mr. Obvious
Old Oct 26, 2005 | 11:52 PM
grlracer97's Avatar
Default Re: (JDMlyfestyle)
If you had codes previously and then think you fixed the problem, make sure you reset the battery so that the codes will reset. Then its just as stated above.^^^
Old Oct 27, 2005 | 02:15 AM
lv6l's Avatar
roger that.
Old Oct 27, 2005 | 04:01 PM
yee SERIOUS's Avatar
did u have a CEL to start with? or do u still have a CEL going?
music462
Apr 10, 2008 05:37 AM
beeroh
Sep 24, 2004 08:16 AM
quikrpm'z
Sep 21, 2004 09:49 PM
fe519
Feb 24, 2004 04:49 PM
Soled Out
Jan 26, 2003 05:47 AM
