Tranny grinds after 5krpms, what fluid should I try? H22A
Old Oct 26, 2005 | 10:33 PM
n8dogg's Avatar
Default Tranny grinds after 5k rpms, what fluid should I try? H22A
My h22a tranny grinds after vtec engagement, Id like to try changing the fluid before I go to the track this sunday. Any suggestions? Synchromesh? What weight?
Old Oct 26, 2005 | 10:35 PM
petern101's Avatar
Default Re: Tranny grinds after 5krpms, what fluid should I try? H22A (n8dogg)
you can try gm syncromesh fm or redline mtl
i only use those and used to use honda mtf
Old Oct 26, 2005 | 10:47 PM
herovueboi's Avatar
This stuff worked out great for me, thought I believe it really is just thicker oil as I've been told. Correct me if I am wrong please, I wouldn't like to give out false information.
Anyways, I used this stuff on my H23A transmission and has yet to fail me. I do it about every 3rd oil change. Which is about every 10k miles. Also, autozone is where I pick it up as well.
Old Oct 26, 2005 | 11:07 PM
n8dogg's Avatar
Default Re: (herovueboi)
what weight do u use? or is it all one weight?
Old Oct 26, 2005 | 11:10 PM
herovueboi's Avatar
I believe it is just all one wait. It comes in that yellow bottle, that is the only color and style that I have seen at autozone so you can't miss it.
Old Oct 27, 2005 | 12:10 AM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by herovueboi &raquo;</TD></TR><TR><TD CLASS="quote">
Anyways, I used this stuff on my H23A transmission and has yet to fail me. I do it about every 3rd oil change. Which is about every 10k miles. Also, autozone is where I pick it up as well.</TD></TR></TABLE>
actually, it is a thinner weight oil, which makes the tranny shift smoother.
i wouldn't recommend it for healthy trannies since it won't protect like the proper spec MTF would, but once you've got a grind, SM will help.
SM works by facilitating more friction, thereby helping synchros get up to speed faster and lead to smoother shifts. problem is, in high-demand situations the friction is exactly what's killing your tranny, slowly.
so, i think the general rule is:
healthy no grind tranny = Honda MTF
not quite so healthy, may need a rebuild at some point tranny = GM SM
there are 3 varieties of SM. the GM SM, the GM SM Friction Modified, and the Pennzoil SM.
as far as i know, the Pennzoil and the GM SM are the same fluid (the penzoil is half the price of the GM SM), and the GM SM FM (heh) is even thinner than the garden variety SM and a synthetic basestock oil. i could be wrong about the GM SM FM's viscosity though...
Old Oct 27, 2005 | 12:24 AM
ahs1219's Avatar
how many bottle you need to fill tranny fluid
Old Oct 27, 2005 | 12:25 AM
bad-monkey's Avatar
Default Re: (ahs1219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahs1219 &raquo;</TD></TR><TR><TD CLASS="quote">how many bottle you need to fill tranny fluid</TD></TR></TABLE>
tranny case capacity is 2.1 qt
Old Oct 27, 2005 | 04:24 AM
HxClude's Avatar
BG Synchroshift!!!
If it can keep Mitsu Eclipse trannies from grinding, it can fix ANYTHING
try here
http://www.prostreetonline.com/buy/bg_synchroshift/
Old Oct 27, 2005 | 07:55 AM
brandond's Avatar
B A N N E D
Default Re: (HxClude)
gm syncromesche bitches it works wonders
Old Oct 27, 2005 | 07:56 AM
n8dogg's Avatar
Default Re: (brandond)
is it GM as in General Motors?
Old Oct 27, 2005 | 08:26 AM
integlude's Avatar
Default Re: (n8dogg)
yes
jdm_obsession88
Sep 1, 2009 02:09 PM
rawNArsxS
Jan 29, 2007 10:33 AM
xd69
Jun 18, 2005 10:51 AM
BahamaEKcrvtec
Jan 5, 2005 05:06 PM
wizzards581
Jul 25, 2004 02:47 PM
