Replacing Front Turn Signal Bulb
I haven't had to replace a turn signal bulb on my car yet...well, the time has finally come that it went out.
How do I replace the bulb? I have taken all the bolts out that I can find and the headlight itself still seems to be caught on something, or is there another bolt that I am not taking out?
The bulb that is out is my Left front turn signal.
Can anyone help with the easiest way to replace?
Thanks so Much!
Thanks so Much!
if this is for an 92-95 civic simply
pop your hood, look at the corner light there should be a phillips screw above it (you cant miss it) unscrew that and you would be able to slide out the corner light, onces its out of place look behind it **
just turn it clockwise or counter and it will pop out ***note*** when putting in the new bulb, it will work both ways , so try out both ways and see which gives a better lighting
slamstrom
Apr 12, 2017 04:50 AM
