help Crankshaft bolt/pulley
Old Oct 26, 2005 | 03:58 PM
d124g0n's Avatar
Default help Crankshaft bolt/pulley
is the crankshaft bolt reverse threading?
I still canot get this bolt off.
Old Oct 26, 2005 | 04:29 PM
Eddiebx's Avatar
no its regular threading
Old Oct 26, 2005 | 05:19 PM
BB6racer's Avatar
heat, wd40, secure the crankshaft somehow there are quite a few ways to do this, and use a fairly long breaker bar. i used a 4ft extension to get mine off. and use anti-seize or assembly lube when you put it back on, it will help next time.
Old Oct 26, 2005 | 05:44 PM
manman's Avatar
Default Re: (BB6racer)
1/2 in air gun if to tight for that hit it with the 3/4in air gun
Old Oct 26, 2005 | 07:06 PM
SteveoBA8's Avatar
Default Re: (manman)
Jumping on the breakover+ cheater bar broke mine loose. I used the honda pulley holder tool.(Good if you dont have air tools). Good luck, its a fighter.
Old Oct 26, 2005 | 07:48 PM
RC's ride's Avatar
Default Re: (SteveoBA8)
i should be breaking mine lose soon whats the best way to secure the crank anybody?
Old Oct 26, 2005 | 11:05 PM
Eddiebx's Avatar
the crank pully eholder tool is the best way to hold it. next best thing is to shove a pry bar into the ring gear on the flywheel
Old Oct 28, 2005 | 06:43 AM
shutta's Avatar
i went to autozone to get that tool from the loan-a-tool thing and they had no idea what i was talking about..
Old Oct 28, 2005 | 06:46 AM
BDRphaSe2's Avatar
autozone is stupid u can ask the for camshaft for your 2005 mazda rx7 and they bring you some
Old Oct 28, 2005 | 07:31 AM
SteveoBA8's Avatar
Default Re: (BDRphaSe2)
I ordered mine off the net, just search yahoo for Honda Crank pulley Holder Tool. Mine was $60
Old Oct 29, 2005 | 07:37 AM
RC's ride's Avatar
there has got to be a cheaper way to do this .. with a decent set of tools..what if you keep the front passenger side tire firmly on the ground and the car in gear would this work???? can you keep the crank still like that??
Powered By Garrett
Nov 4, 2010 10:00 AM
almostjdmeg
Jan 6, 2009 08:09 PM
projectjazzmine
Jan 20, 2007 08:55 PM
Teg_93
Jan 15, 2007 06:55 AM
xxmastermindxx
Aug 22, 2006 09:22 PM
