OT: Good tire inflator?
Old Oct 26, 2005 | 02:06 PM
onyx00's Avatar
Default OT: Good tire inflator?
Can anyone recommend a good tire inflator? I have searched Amazon and a lot of people complain most compressors do not move enough air volume to inflate stuff in a reasonable amount of time. I just can't seem to find anything that looks decent. I want to avoid trips to the gas station to adjust the pressure in my tires.
Old Oct 26, 2005 | 02:08 PM
Mugen Mike's Avatar
Default Re: OT: Good tire inflator? (onyx00)
or
http://www.herringtoncatalog.com/m649.html
Old Oct 26, 2005 | 02:32 PM
Desired_Speeds's Avatar
bicycle pump
Old Oct 26, 2005 | 02:34 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: (Desired_Speeds)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Desired_Speeds &raquo;</TD></TR><TR><TD CLASS="quote">bicycle pump </TD></TR></TABLE>
One of my old neighbors had a Mazda 929 he kept garaged. Why I don't know, but the car was immaculate, and had maybe 6k miles on it. I'd see him every Friday afternoon checking tire pressures and airing them up as needed with a bicycle pump.
Old Oct 26, 2005 | 02:42 PM
SamC's Avatar
Default Re: (Splat)
time for an air compressor and air tools.
Old Oct 26, 2005 | 02:51 PM
98 Spec R's Avatar
Default Re: (SamC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SamC &raquo;</TD></TR><TR><TD CLASS="quote">time for an air compressor and air tools.</TD></TR></TABLE>
Spend a little bit more money and get a compressor so you can then invest in some air tools in the future. It will make you life a lot easier for future repairs.
Old Oct 26, 2005 | 02:56 PM
TypeRPaul's Avatar
are you looking for a home unit or a light weight unit for after running at the track?
Old Oct 26, 2005 | 08:10 PM
jetydosa's Avatar
25 Year Member
Default Re: (TypeRPaul)
I bought one of these for use at autox and track, it works pretty well
http://www.walmart.com/catalog...=3992
Its a bit on the slow side but usually you are only adjusting up ~10lbs or so. Doesnt take to long, no cords to worry about and lasts forever, FOREVER, on a single charge.
Old Oct 26, 2005 | 08:15 PM
.water's Avatar
this work too??
http://www.sears.com/sr/javasr...13000
i dont know how this little thing can push out air..lol
Old Oct 26, 2005 | 10:41 PM
KayOs's Avatar
Old Oct 26, 2005 | 11:05 PM
mugenracer's Avatar
I bought the cheapest nastiest compressor i could find, it cost me about $10, it takes 3-5 minutes to inflate a soft tyre to the correct pressure, but it does the job and the gauge on it is pretty accurate. Why pay a ball of money for something thats only going to do the job a minute or two quicker. The way i look at it, if i was somewhere and discovered i had a soft tyre then to hell with how long it takes, so long as i dont have to drive on it to a gas station to get to an air pump!
Old Oct 26, 2005 | 11:22 PM
.water's Avatar
Default Re: (mugenracer)
so one that i linked. that will work just fine?
Old Oct 27, 2005 | 05:12 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">I bought the cheapest nastiest compressor i could find, it cost me about $10, it takes 3-5 minutes to inflate a soft tyre to the correct pressure, but it does the job and the gauge on it is pretty accurate. Why pay a ball of money for something thats only going to do the job a minute or two quicker. The way i look at it, if i was somewhere and discovered i had a soft tyre then to hell with how long it takes, so long as i dont have to drive on it to a gas station to get to an air pump!</TD></TR></TABLE>
You can find small, lightweight units that plug into your cigarette lighter at any auto parts store as well as discounters like Wal-Mart or Target for $10-15.
Old Oct 27, 2005 | 12:04 PM
Eva01's Avatar
I got mine at the 'Zone for 20$. I've been saving quarters ever since.
Old Oct 27, 2005 | 12:07 PM
Dave_B's Avatar
Another option if you already have a compressor at home is a small air tank. I used to use one of these at the drag strip after I lowered tire pressure. Another option is a pancake compressor. You can pick one of these up at a pawn shop cheap.
accordfreak
Apr 12, 2006 02:08 PM
integra3586
Nov 11, 2005 02:24 PM
HS2G
Jul 10, 2005 01:13 AM
b20turboic
Aug 10, 2003 07:01 AM
TurBoXBirD16
14
Jun 11, 2003 03:24 PM
