what should it idle at...
Old Oct 26, 2005 | 10:28 AM
hamburgler's Avatar
Default what should it idle at...
i seached but could find what i really was looking for.......but what should my car be idling at .....it idles a 1 and thought that was a little low.......its a 95 rs
Old Oct 26, 2005 | 10:30 AM
ultima's Avatar
Default Re: what should it idle at... (carless87)
usually it should idle in between 700 and 900 RPMs if u think it is idling to high look on ur throttle body for ur idler screw. This will allow u to adjust ur idle.
Old Oct 26, 2005 | 10:34 AM
hamburgler's Avatar
ok thanks man than its idling fine.....for some reason i thought it should be about 1300......o well haha
Old Oct 26, 2005 | 11:06 AM
shamoo's Avatar
Will you make something up for me please?
According to the Helms:
Idle speed with headlight and cooling fans OFF: 750 plus or minus 50rpm
This is in both manual and automatic transmissions (auto being in the N or P position).
Old Oct 26, 2005 | 11:08 AM
HONDA RR's Avatar
IT SHOULD BE BELOW 1000 RPM
Old Oct 26, 2005 | 08:30 PM
Johnny_Rocket's Avatar
Default Re: what should it idle at... (HONDA RR)
750 RPM's... 1,000 is too high... maybe check for vacuum leaks too along with the idler screw
Old Oct 27, 2005 | 12:04 AM
suzawa94's Avatar
Default Re: what should it idle at... (JohnnyH)
^^ 750 +/- 50rpm. should be when the vehicle is at normal operating temp. (195-200 deg. F) or little below 1/2 on coolant temp gauge.
about 1200rpm when vehicle is cold is normal
PINKS
May 29, 2006 10:26 PM
chahsiubow
Jun 6, 2004 07:26 AM
Ian in Oz
Jun 4, 2003 10:21 AM
cj7420
Mar 24, 2002 06:55 AM
rotaryguy
Feb 21, 2002 03:36 PM
