intake air temp?
Old Oct 26, 2005 | 07:21 AM
redricer's Avatar
Default intake air temp?
what is the normal Intake Air Temperature on a stock d16y8? Mine is reading 250 degrees and that seems high.
Old Oct 26, 2005 | 07:38 AM
Slow EJ8's Avatar
Default Re: intake air temp? (redricer)
Not sure but I suppose it would have something to do with outside temp as well. What is the outside temp when you took that reading?
In for the answer too cuz I wanna know.
Old Oct 26, 2005 | 07:44 AM
gftgrill's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redricer &raquo;</TD></TR><TR><TD CLASS="quote">what is the normal Intake Air Temperature on a stock d16y8? Mine is reading 250 degrees and that seems high. </TD></TR></TABLE>
it's usually about the outside temp + more if the engine bay is hot, but I wouldn't think more than 10-15 degrees.
so unless it's about 235 degrees where you live, something is wrong.
Old Oct 26, 2005 | 07:45 AM
gftgrill's Avatar
also, do you have a short ram intake? that could be why the reading is so high if it's sucking in hot engine bay air.
Old Oct 26, 2005 | 09:49 AM
redricer's Avatar
it was no more than 60 degrees out side when it was tested there is probally something wrong with my senser
Old Oct 26, 2005 | 11:29 AM
redricer's Avatar
i still want to know what the average temp is
Old Oct 26, 2005 | 11:31 AM
SRCivic97's Avatar
Default Re: (redricer)
Did you install an autometer gauge? Where did you install the sending unit to take this measurement? It's going to read higher if you have a short ram. If you have a cold air it's going ot read much lower.
Old Oct 26, 2005 | 11:44 AM
gftgrill's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redricer &raquo;</TD></TR><TR><TD CLASS="quote">i still want to know what the average temp is</TD></TR></TABLE>
there is no average temp. the temp that it's reading is going to be directly related to the air around it.
thus you will get different readings if you live in alaska vs if you lived in south florida.
I guess to answer your question you would have to do some math and average the temperature of every spot on earth. then add a few degrees for the motor running.
pr0jkt
Honda Civic (2001 - 2005)
10
Oct 22, 2006 11:55 AM
92c1v1cHATCH
14
Sep 13, 2006 08:29 AM
hondaracin24
Nov 17, 2004 06:56 AM
