JDM B16A1 question...
Old Mar 7, 2002 | 01:48 PM
KamikazeTypeR's Avatar
New User
Default JDM B16A1 question...
I recently purchased a JDM B16A1 motor. Found out the motor use to be attached to a auto tranny. Can I run the motor with a manual tranny(JDM J1 tranny)? I also have a manual ECU. Also will the motor be as fast as a manual motor? Thanks.
Old Mar 7, 2002 | 02:07 PM
EL Vap133's Avatar
Default Re: JDM B16A1 question... (KamikazeTypeR)
I assume so but I heard that the valve springs are different, not too sure though.
Old Mar 7, 2002 | 02:09 PM
meept's Avatar
Default Don't see why not....
...You'll have to get a flywheel, but aside from that it should bolt right up. I don't think there is any difference in the motor itself with an auto, just the ECU and tranny/flex plate.
Old Mar 7, 2002 | 02:29 PM
RexB16's Avatar
Default Re: Don't see why not.... (meept)
the automatic b16 has milder cams good for 155 hp.
Old Mar 7, 2002 | 03:45 PM
afstlsvtec's Avatar
it will work and you know that since it was a auto it was not ran as hard as a manual...
Joshyboy2929
May 20, 2018 06:17 PM
aziaticvang
Mar 23, 2009 02:53 PM
_EF9
Transmission & Drivetrain
Mar 18, 2009 05:33 PM
RockLee`
15
Aug 25, 2005 05:23 PM
Sharky NRK
Mar 3, 2004 06:32 PM
