obd-1 ecu code 1 will not go away
Old Oct 25, 2005 | 04:56 PM
mx621's Avatar
Default obd-1 ecu code 1 will not go away
and yes i have done a search. ek with gsr swap, obd1 ecu throwing code 1, which is primary o2 sensor. i have replaced the sensor, checked all grounds, checked signal input from o2(like .7-.9 mv) while car is warm, have 12v on output to heater. ohmed out the sensor 10ohms. have no shorts, and continunuity from sensor to pins entering ecu, and all is seems ok, and still is throwing the code. is even throwing the code on the obd-2 ecu that i have, so thats tells me that its not the ecu. is there any thing i am missing, this is driving me crazy.
Old Oct 26, 2005 | 02:59 AM
mx621's Avatar
Default Re: obd-1 ecu code 1 will not go away (mx621)
anyone
Old Oct 26, 2005 | 02:19 PM
mx621's Avatar
no one on here has had or herd of this problem??
Old Oct 26, 2005 | 02:38 PM
Luserkid's Avatar
What year is the motor? OBD1? What harness are you running? Was the car 4 wire before you put the motor in?
I would wire the o2 straight to the ecu and see if that helps.
Old Oct 27, 2005 | 01:41 PM
mx621's Avatar
Default Re: obd-1 ecu code 1 will not go away (Luserkid)
its a 95 gsr motor, with moded stock harness, ecu is a chipped p-28, throws same code with my obd-2 p75 ecu that i use to get through inspection. im working on geting a new harness, like an ex or so. drives my ****** nuts
Old Oct 27, 2005 | 01:48 PM
JdmB16Eg6's Avatar
65.115.123.226
try to disconnect your battery with your ecu out. worked for me
Nick97hatch
May 29, 2010 05:51 AM
2Point3
May 20, 2009 05:18 PM
tpdc2
Sep 6, 2007 10:21 AM
cheeks97R
Apr 17, 2005 09:34 AM
initialR
Jan 10, 2005 10:06 AM
