Car shuts off while driving.
Old Oct 25, 2005 | 12:36 PM
d16y8EL's Avatar
Default Car shuts off while driving.
My car runs fine, there's no other problems. But now and then my car will just shut off, it always seems to happen just after i turn a corner.
It will start up just fine after it shuts off. It doesnt spurt, gurgle, chug or do anything odd when it shuts off. It just shuts off.
Any help would be appreciated. i doubt its my alternator, i disconnected my battery while the car was running and it didnt shut off. My best guess would be the dizzy, but i dont know how to go about checking to see if thats the problem.
Old Oct 25, 2005 | 12:40 PM
RedEK9's Avatar
Default Re: Car shuts off while driving. (d16y8EL)
Make sure you check all your grounds, as well as check the timing, that was the issue once in my dads van and it turned out to be the timing had advanced a couple of teeth somehow...
Good Luck
Old Oct 25, 2005 | 12:55 PM
peacexisxfree's Avatar
check your rotor in the dizzy as well. if it is around corners, perhaps its a fuel supply problem. your fuel filter clean?
Old Oct 25, 2005 | 12:56 PM
d16y8EL's Avatar
new fuel filter, timing belt, wp, valve adjustment <5k ago
o5mar1's Avatar
checking your alternator by removing the battery cable is a hack way of checking and more often it causes harm to the alternator. Next time you want to check your alternator go to radio chack buy a cheap multimeter and put the leads on the battery while the car is runing and you should get like 13.4-14.5 volts that means your alternator is charging.
Old Oct 25, 2005 | 12:58 PM
boosted civic 2k6's Avatar
it could always be you're battery. check to see if the terminals are lose. i jumped my car once and shut it off. wouldn't start back up. terminal was loose.
Old Oct 25, 2005 | 02:34 PM
impact_blu's Avatar
check your grounds, a wire might be loose. My car died on me on corners before and it turned out to be a bad ground connection. gl.
Old Oct 25, 2005 | 02:38 PM
d16y8EL's Avatar
does anyonbe have a picture showing where the grounds on a 4dr EX would be? i'm a moron when it comes to electrical
Old Oct 26, 2005 | 09:50 PM
d16y8EL's Avatar
bump
JDM-EJ1's Avatar
Default Re: (peacexisxfree)
My vote is gonna goto dizzy and ofcourse the fuel filter.
Old Oct 29, 2005 | 03:45 PM
JDMek498's Avatar
i have the same problem, although i had replaced my spark plugs, wires, rotor, distributor, and got my alternator checked out at auto-zone [said it was fine]. I had also replaced my fuel filter and im still having a problem with it. i have sloppy idle, cold start is fine, if i dont warm up the car, itll die once i put it into nuetral or itll idle really really low and sometimes just shut off. all parts were replaced with OE parts as well. i need help too! car still runs, but its annoying and embarassing when youre next to another car and your car shuts off.
Old Oct 29, 2005 | 07:14 PM
91IntegraX's Avatar
had that prob with my CRX Si .....make sure all ur alternator wires are hooked up to it and maybe get it tested at ur local autozone or w/e u got
Old Oct 29, 2005 | 07:26 PM
808_si's Avatar
Default Re: (o5mar1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o5mar1 &raquo;</TD></TR><TR><TD CLASS="quote">checking your alternator by removing the battery cable is a hack way of checking and more often it causes harm to the alternator. Next time you want to check your alternator go to radio chack buy a cheap multimeter and put the leads on the battery while the car is runing and you should get like 13.4-14.5 volts that means your alternator is charging.</TD></TR></TABLE>
negative and positive or what? never used a multimetter before...
Old Oct 29, 2005 | 08:08 PM
kkim's Avatar
Default Re: (808_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808_si &raquo;</TD></TR><TR><TD CLASS="quote">
negative and positive or what? never used a multimetter before...</TD></TR></TABLE>
Should read positive voltage. Set your mutimeter to DC, put the red lead on the positive terminal of the battery and the black lead to the negative terminal.
To the original poster, check to see if you have spark at the plugs when the problem occurs. If no spark, I'd bet either the ignitor or HV coil in the distributor is the problem... very common in Hondas/Acuras.
Old Oct 29, 2005 | 08:13 PM
808_si's Avatar
thanks for the info, i think my starter or alternator went out tonight...
xPhantomSolx's Avatar
Just a thought... if it's not an electrical issue, my dad had the same problem in his 00 impala.. the whole fuel delivery system was FUBAR, but it had started with shorts/bad grounds/in general crappy domestic wiring on the fuel pump...
smokey68321
Apr 18, 2010 05:20 PM
BiG_DeE
11
Feb 1, 2008 02:08 PM
S2k Hybrid
12
Apr 24, 2007 09:41 PM
mtownsi
Jun 3, 2006 07:14 PM
junya16
Mar 1, 2003 05:41 PM
