Idle problem
Old Oct 25, 2005 | 07:56 AM
jdmCivic925's Avatar
Default Idle problem
heres the deal...lastnight i start my car and my idle was below 600rpm the engine was about to die... i check the timing its fine but the rpm was still da same....help!
Old Oct 25, 2005 | 08:43 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Idle problem (jdmCivic925)
Clean your IACV. Do a search, and there's a how-to on this. Could be dirty. If everything is fine, perhaps just adjust your idle with the adjustment screw on the throttle body.
Do you have any modifications? Vacuum leak somewhere? Throwing any codes?
Old Oct 25, 2005 | 08:45 AM
Backk InTheDA's Avatar
I hate everything
Default Re: Idle problem (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">Clean your IACV. Do a search, and there's a how-to on this. Could be dirty. If everything is fine, perhaps just adjust your idle with the adjustment screw on the throttle body.
Do you have any modifications? Vacuum leak somewhere? Throwing any codes?</TD></TR></TABLE>
^^Seriously, you know everything lol.
Old Oct 25, 2005 | 08:46 AM
MrAngry's Avatar
Here's the deal..
Shotgun *******.
Old Oct 25, 2005 | 02:37 PM
check done, fixed...thankz
TegraD
May 15, 2009 02:55 PM
924doorEG
Nov 19, 2007 08:15 AM
b16a3delsol
Aug 15, 2007 09:29 AM
RUBZERK
Jun 8, 2003 06:29 PM
TheIntegraGuy
Dec 28, 2002 06:49 PM
