Oil consumption with forged pistons???
Old Oct 25, 2005 | 01:51 AM
EITCP's Avatar
Default Oil consumption with forged pistons???
What is your experiences? What oil consumption people have with forged pistons? I've heard it's high, but i wonder how much...
Can you share your experience with it?
thanks.
Old Oct 25, 2005 | 03:21 AM
NJIN BUILDR's Avatar
Default Re: Oil consumption with forged pistons??? (EITCP)
It shouldn't be any higher than cast pistons.Several cars have them as original equipment such as Subaru.
Glenn
Old Oct 25, 2005 | 07:40 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Oil consumption with forged pistons??? (NJIN BUILDR)
Forgive me, as I forgot some of the technical details regarding this issue.
Some colder pistons require them to be under high heat for them to be under operating temperatures. Lots of race pistons are like this. Before they expand to normal operating temperatures, the tolerances will be quite low (or high, depending on how you say it). You could lose some oil during warm up.
I believe it has something to do with the silicone content. Not all forged pistons are this way. I believe this is one of the main differences between the two JE ones. Regular JE, and SRP. JE is colder. SRP has more stock characteristics.
I hope more people chime in on this so I can learn some more too. It's been a while.
Old Oct 26, 2005 | 10:22 AM
EITCP's Avatar
Anybode else would like to share his experience with oil consumption with forged pistons?
Old Oct 27, 2005 | 10:51 AM
Takumi Fujiwara's Avatar
Are people having oil consumption problems with forged pistons?
Old Oct 27, 2005 | 12:55 PM
Antilag's Avatar
Default Re: Oil consumption with forged pistons??? (Takumi Fujiwara)
Arias pistons are like this. They take around 180 degrees to be at optimum performance. You can hear the piston slap when you first warm them up. I have had piston reps that told me that who ever said there is a difference in compression from cold to normal operating temp. is banging there head. Well he and whoever thinks this is wrong!! I checked it first hand yesterday. My pistons are the new inverted wave dome arias 9.5:1. Compression check with the car sitting for a week read as follows 150-145-145-155. After normal operating temps new reading 180-180-180-185. 40 percent leakdown - 4% leakdown , well the valves expanding during heat plays to factor as well too. Motor has already been broke in. Yes the car can burn alittle oil during initial cold start up. Helps if you use 20-50 non synthetic for the first 2000 miles. This will help oil consumption during the cold start up process.
Hope this helps.
Old Nov 1, 2005 | 09:48 AM
Default Re: Oil consumption with forged pistons??? (9sech22civic)
mitchell_2kSiR
Feb 4, 2010 04:01 AM
mitchell_2kSiR
Jul 29, 2008 08:28 AM
Agito
Dec 11, 2007 09:49 PM
FuNkDrSpOt
Jul 29, 2006 12:21 PM
JLHDOHC
Apr 24, 2006 06:17 PM
