Sorry, the search is busted (Fuel cut off)
Old Oct 24, 2005 | 09:47 PM
Spectrum24x's Avatar
Default Sorry, the search is busted (Fuel cut off)
Anyone know where i can find a quick write up on doing a fuel cut off switch on a 91 Integra, iknow the basics, but just wanna make sure theres nothing im missing..
sorry the search was being gay
Old Oct 24, 2005 | 11:25 PM
Default Re: Sorry, the search is busted (Spectrum24x)
bump, anyone?
Old Oct 25, 2005 | 01:49 AM
suzawa94's Avatar
first things i could find......
http://members.***.net/shaundr....html
http://www.team-integra.net/fo...11658
Old Oct 25, 2005 | 04:11 AM
Backk InTheDA's Avatar
I hate everything
Default Re: Sorry, the search is busted (suzawa94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suzawa94 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.team-integra.net/fo...11658
Old Oct 25, 2005 | 07:11 AM
rkrone's Avatar
take out your back seat, there is a hole to you can get to the wires that go to your fuel pump
unplug the harness and use a voltmeter to see which wire goes on with the ignition,
put a switch there
done
i had to rewire my whole harness with a relay because i kept blowing a fuse with a high flow pump, (which on a 90-93 requires dropping the tank completely)
Old Oct 25, 2005 | 08:42 AM
loudassVTEC's Avatar
Default Re: Sorry, the search is busted (rkrone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rkrone &raquo;</TD></TR><TR><TD CLASS="quote">i had to rewire my whole harness with a relay because i kept blowing a fuse with a high flow pump, (which on a 90-93 requires dropping the tank completely)</TD></TR></TABLE>
You sure that you have to drop the tank to put a hi flow pump in?? From my research, and my Helms manual you shouldn't...
Old Oct 25, 2005 | 12:35 PM
Default Re: Sorry, the search is busted (loudassVTEC)
I don't have a voltmeter, so anyone know what color the fuel pump wire is? my friend said it was black yellow on his 90 civic hatch, but i dont see a black yellow on mine, and is it the wires going int the harness coming out from the big round silver thing in the center under the seat?
"Ridge"Racer
Honda Civic (2006 - 2015)
11
Sep 24, 2007 08:51 AM
HybridKOOP
Sep 13, 2007 12:47 PM
96cxt
Mar 10, 2006 11:41 AM
jeffk182
18
Oct 19, 2004 06:16 AM
acintegragsr
Sep 29, 2004 06:18 PM
