Steering Wheel Shaking... need help
Old Oct 24, 2005 | 02:32 PM
SlamminS85's Avatar
Default Steering Wheel Shaking... need help
I recently have noticed that my steering wheel just shakes clockwise/counterslickwise really fast. Could this be a problem with my alignment or with my tires or something. I know cars pretty well except for stearing and suspension. Any suggestions would help, thanks.
Old Oct 24, 2005 | 04:56 PM
Integra_drk's Avatar
Default Re: Steering Wheel Shaking... need help (SlamminS85)
at what speeds does this occur? all the time? When is it the worst?
Old Oct 24, 2005 | 05:13 PM
TealEG!'s Avatar
if it happens when you brake then it is probably your rotors but im sure you already know that and you didnt mention anything about braking but just thought i would check
Old Oct 24, 2005 | 05:47 PM
SlamminS85's Avatar
Default Re: Steering Wheel Shaking... need help (GBPDC2)
its not my rotors, but ti occours most noticeably at about 20-35 mph... at high speeds i dont notice a thing untill i hit 88 MPH (which is when the flux... nevermind), but seriously around 85-90 it starts the shaking again, but ti is the worst when in the 20's, i just had my breaks checked out and they are fine, i know i am goign to need new tires soon, but im gonna try to make it to march first
i also have been doing a lot of powersliding in slightly wet parking lots late at night, at about 30 ill cut the wheel and pull the e-brake
Modified by SlamminS85 at 6:58 PM 10/24/2005
Old Oct 24, 2005 | 05:51 PM
Rajin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlamminS85 &raquo;</TD></TR><TR><TD CLASS="quote">its not my rotors, but ti occours most noticeably at about 20-35 mph... at high speeds i dont notice a thing untill i hit 88 MPH (which is when the flux... nevermind), but seriously around 85-90 it starts the shaking again, but ti is the worst when in the 20's, i just had my breaks checked out and they are fine, i know i am goign to need new tires soon, but im gonna try to make it to march first
i also have been doing a lot of powersliding in slightlyl wet parking lots late at night, at about 30 ill cut the wheel and pull the e-brake</TD></TR></TABLE>
Thats what you mean
Old Oct 24, 2005 | 05:58 PM
SlamminS85's Avatar
Default Re: Steering Wheel Shaking... need help (Rajin)
regardless of what i mean i dont like my shakin wheel
Old Oct 24, 2005 | 06:08 PM
TealEG!'s Avatar
if you slid out enough you could have a slight flat spot in your tires depending on how soft they are. try switching your back tires with a friends for a while and see how it is.
Old Oct 24, 2005 | 06:12 PM
lhd dc2's Avatar
Is it the front? Your wheels probably just needs to be rebalanced. Mines are doing that at certain speeds. And I know its my front right wheel that is off balanced.
Old Oct 24, 2005 | 06:47 PM
SlamminS85's Avatar
Default Re: Steering Wheel Shaking... need help (DBtwo)
no its not my wheels that are vibrating, its my steering wheel, shaking about a quarter inch clockwise and counter clockwise when i drive about 20 - 35 MPH, i think it has to do wiht my allignment
Old Oct 24, 2005 | 07:15 PM
GserpleaSR's Avatar
Your wheels are connected to your steering wheel! so if you have a bad tires, bad rotors, or loose suspension then guess what? Your steering wheel is going to shake!!
Old Oct 24, 2005 | 07:24 PM
Rajin's Avatar
Default Re: Steering Wheel Shaking... need help (pzero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pzero &raquo;</TD></TR><TR><TD CLASS="quote">Your wheels are connected to your steering wheel! so if you have a bad tires, bad rotors, or loose suspension then guess what? Your steering wheel is going to shake!!</TD></TR></TABLE>
Thats right, any problem with any of the listed items will cause irregularities.
Old Oct 24, 2005 | 10:06 PM
SlamminS85's Avatar
i honestly think its an alignment problem, but could be tires, only happens right around 38 mph, so whatever, i just wont drive 38 on the highway
Old Oct 25, 2005 | 12:35 AM
racingfan's Avatar
I got the same problems too sometimes.. but after I got my tire rebalanced NO MORE SHAKED STEERING WHEEL
Old Oct 25, 2005 | 04:22 AM
Backk InTheDA's Avatar
I hate everything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GBPDC2 &raquo;</TD></TR><TR><TD CLASS="quote">if it happens when you brake then it is probably your rotors but im sure you already know that and you didnt mention anything about braking but just thought i would check
Old Oct 25, 2005 | 05:53 AM
2005 TSX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlamminS85 &raquo;</TD></TR><TR><TD CLASS="quote">I recently have noticed that my steering wheel just shakes clockwise/counterslickwise really fast. Could this be a problem with my alignment or with my tires or something. I know cars pretty well except for stearing and suspension. Any suggestions would help, thanks.</TD></TR></TABLE>
Ok, so it could be a couple of things...
1. Your tires/rims are probably unbalanced.
2. You could have flat spots on your tires due to your e-brake manuvering.
3. You could have blown your shocks.
4. You could need an alignment.
Here are a couple of questions to ask yourself...
Is your car lowered?
If your car is lowered, by how much is the car lowered?
Whewn is the last time you had an alignment?
Do you have a camber kit installed?
Is your suspension fairly new or is it old?
What kind of setup do you have?
How old are your tires?
When is the last time you had the tires balanced and rotated?
Are your rims bent?
Some more information would be helpful for us.
Old Oct 25, 2005 | 06:02 AM
2005 TSX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlamminS85 &raquo;</TD></TR><TR><TD CLASS="quote">...i know i am goign to need new tires soon, but im gonna try to make it to march first
If you want your tires to last until March, you probably should stop your late night parking lot driving.
Just a thought.
Old Oct 25, 2005 | 12:50 PM
SlamminS85's Avatar
Default Re: Steering Wheel Shaking... need help (2005 TSX)
good point, here is more info on my car:
Is your car lowered? NO
Whewn is the last time you had an alignment? Not for a year actually.
Do you have a camber kit installed? NO
About this, the suspension is original suspension but the car only has 70k on it... BUT it was sitting in some old ladys garage for years doing nothing.
What kind of setup do you have? Stock
How old are your tires? Old
When is the last time you had the tires balanced and rotated? 8 Months or more
Are your rims bent? NO
p0tential
Suspension & Brakes
Mar 8, 2008 10:20 PM
p0tential
11
Feb 28, 2008 09:33 AM
upwind
May 12, 2005 06:10 PM
crxaddikt
Feb 10, 2004 08:55 AM
Jmm0056
Jan 13, 2002 06:08 PM
