Integrated control unit removal
Old Oct 24, 2005 | 09:53 AM
B18EG6's Avatar
Default Integrated control unit removal
does anyone know how to remove this? Its the colored box on back of the underdash fusebox
BEFORE you say helms:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by helms &raquo;</TD></TR><TR><TD CLASS="quote">Remove the dashboard lower cover and knee bolster, then disconnect the 15-p connector from the ICU.
Remove the ICU from the underdash fuse/relay box.</TD></TR></TABLE>
TIA
Old Oct 24, 2005 | 10:54 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: Integrated control unit removal (B18EG6)
If you're in a DA, it's behind the fuse panel on the driver kick...I MEAN ON THE BACK OF THE FUSE PANEL...unbolt it, and then be careful and remove it with a big pick or a flathead...
let me know what problems you're having....I've dealt with this thing before...it's a pain in the ***
Old Oct 24, 2005 | 12:36 PM
B18EG6's Avatar
Default Re: Integrated control unit removal (DAantagonist)
yeh its from a DC. I got the fusebox at home, just dunno how to get the ICU out of it.
where do you pry to get it out?
Old Oct 24, 2005 | 03:01 PM
DirtyBirdJR's Avatar
i think it is snaped together. just use a flathead and work around it. gl
Old Oct 25, 2005 | 01:11 PM
B18EG6's Avatar
Default Re: Integrated control unit removal (DirtyBirdJR)
awesome, ill try that as soon as possible (fusebox is 120 miles away from me )
antagonist - is this how you did it, just pry that sucker off?
EDIT- out of curiosity... does anyone know for SURE if another ICU will plug into the teg fusebox? Say, a 95 civic's?
slowexcoupe
39
Dec 14, 2022 08:27 AM
accord96lx
Dec 11, 2018 01:19 PM
Olias
Mar 28, 2014 11:30 AM
s1ngle
17
Feb 19, 2007 04:05 PM
hagrid
Dec 22, 2002 07:01 PM
