HELP!! Integra won't start after clutch install?!!
Old Oct 24, 2005 | 12:41 PM
95greenteg's Avatar
Default HELP!! Integra won't start after clutch install?!!
Ok
my bro's friend intalled my new Exedy clutch this weekend and for some reason it does not start until after about 3 to 5 turns on the ignition....All I hear is a click when I try to turn the key on the ignition...What could be the problem?
Modified by 95greenteg at 4:56 PM 10/24/2005
Old Oct 24, 2005 | 01:21 PM
shorto85's Avatar
Double check all of your starter connections...
When you turn the key and you only hear a single click then that indicates the starter is going out. I had the same symptoms and I replaced my starter and it fixed the problem.
Old Oct 24, 2005 | 02:56 PM
95greenteg's Avatar
Default Re: (shorto85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorto85 &raquo;</TD></TR><TR><TD CLASS="quote">Double check all of your starter connections...
When you turn the key and you only hear a single click then that indicates the starter is going out. I had the same symptoms and I replaced my starter and it fixed the problem.</TD></TR></TABLE>
I'll check that tomorrow morning...thanks
Old Oct 26, 2005 | 12:46 PM
95greenteg's Avatar
Default Re: (95greenteg)
Okay I've checked a couple connections but no results...It's still doing the same thing...It would still start...Sometimes it starts on first try, sometimes it takes a couple tries...Any other suggestions?
Old Oct 26, 2005 | 05:27 PM
Sam92Teg's Avatar
Usually, it is loose connections, weak battery, or bad starter. Check in that order. Make sure the negative battery connection to the tranny bracket is tight, as well as the starter connections. My guess would be weak battery since it sat for awhile probably.
Old Oct 26, 2005 | 05:46 PM
95greenteg's Avatar
Default Re: (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">Usually, it is loose connections, weak battery, or bad starter. Check in that order. Make sure the negative battery connection to the tranny bracket is tight, as well as the starter connections. My guess would be weak battery since it sat for awhile probably.</TD></TR></TABLE>
well, it sat for about 3 days...Wouldn't the car crank if it was a weak battery? My guess is a bad connection...I guess I will be checking more connections...
Old Nov 6, 2005 | 06:01 AM
95greenteg's Avatar
Default Re: HELP!! Integra won't start after clutch install?!! (95greenteg)
YES!!!! Finally fixed my car! Did the starter rebuild from the articles section on Team-Integra.com and BAM! It starts like a dream! I'm excited cause I saved over $100 by doing this...Big shouts to fast95se on T-I for discovering this
Old Nov 6, 2005 | 07:39 AM
ITB
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95greenteg &raquo;</TD></TR><TR><TD CLASS="quote">YES!!!! Finally fixed my car! Did the starter rebuild from the articles section on Team-Integra.com and BAM! It starts like a dream! I'm excited cause I saved over $100 by doing this...Big shouts to fast95se on T-I for discovering this </TD></TR></TABLE>
cool... i hate it when you JUST install something and something else breaks, and makes you think its connected in some way but its not, confuses the expletive outta everybody. good thing you found out what it was
Old Nov 6, 2005 | 08:37 AM
projectTeG's Avatar
what be this starter rebuild you talk of?
Old Nov 6, 2005 | 09:59 AM
gsr dood's Avatar
Default Re: HELP!! Integra won't start after clutch install?!! (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">what be this starter rebuild you talk of?</TD></TR></TABLE>
you clean all the old crap that ***** around in the starter. u get a better conection. its the #1 cause of starter failures.
Old Nov 6, 2005 | 07:48 PM
95greenteg's Avatar
Default Re: HELP!! Integra won't start after clutch install?!! (gsr dood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood &raquo;</TD></TR><TR><TD CLASS="quote">
you clean all the old crap that ***** around in the starter. u get a better conection. its the #1 cause of starter failures.</TD></TR></TABLE>
nah man...just check the link...
http://www.team-integra.net/se...=1079
Old Nov 6, 2005 | 08:05 PM
projectTeG's Avatar
http://www.team-integra.net/se...=1079</TD></TR></TABLE>
how much was the kit from toyota?
Old Nov 6, 2005 | 08:34 PM
allhonda's Avatar
hey make sure the starter nut is tied and secured
Old Nov 7, 2005 | 01:29 PM
95greenteg's Avatar
$20 for both kits...
Jovani922
Aug 25, 2011 06:02 AM
Hanmin
May 2, 2010 05:01 PM
PDXHatchback
Mar 5, 2007 07:38 PM
ilu
Nov 15, 2005 01:20 PM
253EK
Oct 9, 2002 11:40 AM
