Time for a new clutch??
Old Mar 7, 2002 | 09:28 AM
3rdGteg's Avatar
Default Time for a new clutch??
My clutch is starting to feel weird all of a sudden. It sometimes don't want to go into 4th gear and sometimes when I do get it in there, it gets stuck (clutch is all the way down) it won't pull back into neutral--sometime it just comes out roughly like there is a restriction--it don't just pop out right away like the other gears. Could this be a sign of a bad clutch or possibly something else? I never experienced a worn clutch before so some inputs would be very helpful.
Thanks.
Old Mar 7, 2002 | 10:52 AM
hybridreams's Avatar
Default Re: Time for a new clutch?? (3rdGteg)
Doesn't sound like your clutch...sounds like tranny woes to me.
Old Mar 7, 2002 | 11:57 AM
3rdGteg's Avatar
Default Re: Time for a new clutch?? (joshbm)
no sounds. When I try to push it into 4th, it seems to be something blocking it like it's not the 4th gear slot but it is(straight down). Though when I let my car sit for like a day, the problem goes away for a just a little bit but comes back after a couple rounds of shifting.
Any other ideas???
Old Mar 7, 2002 | 12:17 PM
Gears not going in sounds like bad synchros to me and it sounds like yours are pretty bad.
Old Mar 11, 2002 | 02:25 PM
3rdGteg's Avatar
Default Re: Time for a new clutch?? (hybridreams)
If my snychros are bad, then it would've grind right? I never had any grinding on 4th gear nor have it ever made anykind of noise, etc. I'm hoping it's just my clutch because anything else means no tranportation because of my lack of funds.
Any other inputs from you tranny experts?
Old Mar 11, 2002 | 02:33 PM
blkbeast's Avatar
New User
i have the same problem once in a blue moon. i won't let me go into first gear. it feels like the shifter hits a wall just like yours. it rarely happens though.
Old Mar 11, 2002 | 02:54 PM
BlackOutSi's Avatar
Default Re: Time for a new clutch?? (blkbeast)
How about a bad slave cyl or master cyl not releasing the pressure plate completely? How's the fluid level on the master cyl?
Old Mar 11, 2002 | 05:22 PM
shawnhayes's Avatar
Thanks.
Having just replaced a clutch - my initial problems sounded JUST like yours. When I got the clutch out - BAM - I had a broken spring retainer. It seems that this little bugger, loose in the clutch housing, makes shifting difficult.
Anyway, replaced the clutch. TADAHH. No more shifting problems.
Shawn
Old Mar 11, 2002 | 06:08 PM
volkracing99's Avatar
New User
Recently one of my freind have the same problem with you.
It's your master cyln... have you check the master cyl oil, it might be empty...
Old Mar 12, 2002 | 04:00 PM
3rdGteg's Avatar
Default Re: Time for a new clutch?? (volkracing99)
Thanks peeps for your inputs; I truly appreciate it. I'm gonna check my fluid on my master cylinder tonight; hopefully it's something that simple instead of a messed up synchro/tranny.
Old Mar 12, 2002 | 04:26 PM
3rdGteg's Avatar
Well, I checked my master cylinder and sadly to say it's not that; the fluid is still full to the top with exception that it's black. (Still hoping to God that it's not the tranny!) Would a mechanic know by the feel of it if it's that spring retainer hub or they have to rip the tranny apart to see it?
It's weird, it's only on 4th and no grinds--just a restrictive feeling when putting it in out--when otherwise won't go in at all or won't come out of 4th gear!??
Old Mar 13, 2002 | 08:26 PM
3rdGteg's Avatar
?Please Help.
Old Mar 13, 2002 | 08:29 PM
2000_Civic_Si's Avatar
Sound slike it could be the master cylinder! Have you ever replaced your tranny fluid? I reccomend doing it every 20,000 miles~Well if all else fails you could take it to a professional to ge tit looked at!
Old Mar 14, 2002 | 07:20 PM
3rdGteg's Avatar
Default Re: Time for a new clutch?? (2000_Civic_Si)
So nobody ever had my exact problem and knows huh?
Old Mar 14, 2002 | 07:31 PM
fixhondas's Avatar
Try some Honda MTF- sounds like a worn blocker ring (synchro) or worn collar teeth. Worn synchros don't always grind. Or the fluid you have in your trans stops the gear too fast when shifting. Try the Honda fluid- you might be surprised.
Old Mar 14, 2002 | 07:36 PM
3rdGteg's Avatar
Default Re: Time for a new clutch?? (fixhondas)
Hey fixhondas, if I take the car to the shop, would they have to take the tranny apart to check if it's my synchro?--cuz if they do, that means alot of $$.
Old Mar 14, 2002 | 07:39 PM
fixhondas's Avatar
It will cost $$$ to do just that- put the Honda fluid in- its a cheap way to improve synchro performance. You can determine alot by just driving the car. It is easier to diag a trans problem by driving opposed to just tearing one apart.
Old Mar 14, 2002 | 07:48 PM
3rdGteg's Avatar
thanks fixhondas, I'm still kind of worried--though hoping that the fluid will work; although I'm very pessimistic right now because of my financial situations.
Old Mar 14, 2002 | 07:52 PM
fixhondas's Avatar
If it is also hard to get out of gear- it would suggest a clutch problem- possibly shredded or a hub spring is coming loose or the pressure plate is lopsided- hard to say without driving- fluid might help- but if the clutch is hosed it will still do this.
Old Mar 14, 2002 | 08:14 PM
3rdGteg's Avatar
I guess I'll get a mechanic to test drive hoping he wouldn't charge me. I remember using engine oil for my tranny the last time I changed it--hopefully that's it--But yeah, sometimes there seems to be a wall there at 4th and sometimes I can't pull it out of 4th until pumping the clutch many times--
I also noticed when I REV UP the engine when switching from 3rd to 4th helps it get in there-though there's still that scraping feeling when going in and out--wierd.
Rat Rod
Nov 16, 2010 03:31 PM
jairobeatz
Oct 27, 2006 12:25 AM
dan89crxsi
35
Oct 25, 2004 03:17 PM
sinfulDB1
May 5, 2003 09:26 AM
integra81
Mar 11, 2002 07:43 AM
