1990 accord ECU problems
Old Oct 24, 2005 | 10:19 AM
stevendl's Avatar
Default 1990 accord ECU problems
How can I determine that my ecu is bad? I just replaced the engine and now I get no spark or fuel. I measured the plug at the throtle position sensor and I get no voltage. I have checked the fuse inside and the one under the hood. I just need to be sure the ECU is bad.
Old Oct 24, 2005 | 11:26 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: 1990 accord ECU problems (stevendl)
Have you checked the main relay?
Old Oct 24, 2005 | 03:18 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevendl &raquo;</TD></TR><TR><TD CLASS="quote"> I just replaced the engine and now I get no spark or fuel. </TD></TR></TABLE>
Did you bolt down the ground wire at the t-stat housing?
Old Oct 25, 2005 | 05:59 PM
vedha's Avatar
Default Re: 1990 accord ECU problems (Chiovnidca)
where is the main relay located anyway.
DDTECH
May 11, 2012 08:42 PM
chad olson
Jan 27, 2009 12:35 PM
spooncivic01
Feb 17, 2008 11:29 AM
eg_gsr11
14
Oct 16, 2005 02:16 PM
civicnightmare
14
Jan 17, 2004 07:03 AM
