2.5" or 3" Piping
What size exhaust piping should i go with for my turbo setup? I will be boost around 7lbs. Some say 2.5" is fine, some say go with 3"...What's best for 7lbs of boost. Also, which muffler sounds the best with a turbo engine? I'm looking for something a lot quieter than my N1. I've looked at MagnaFlow. Are they any good?
if your only boosting 7 pounds run 2.5.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">3" is where it's at for turbo.</TD></TR></TABLE>
wise ***.
wise ***.
bigger isn't always better, expecially if your going to run 3 inch all the way from the turbo to the intercooler to the TB the area between 3 and 2.5 adds up.
i run 2.5 , personally i think on 10 pounds it is even overkill. do as you please.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude »</TD></TR><TR><TD CLASS="quote">bigger isn't always better, expecially if your going to run 3 inch all the way from the turbo to the intercooler to the TB the area between 3 and 2.5 adds up.
i run 2.5 , personally i think on 10 pounds it is even overkill. do as you please.</TD></TR></TABLE>
We are talking exhaust piping, not intercooler piping. 2.25" is fine for 450whp and I use 2.5" for up to 650ish.
We are talking exhaust piping, not intercooler piping. 2.25" is fine for 450whp and I use 2.5" for up to 650ish.</TD></TR></TABLE>
I was planning on running 3" all the way around for running 15 psi daily, up to 23 psi when I feel like paying for real gas! You think 2.5" for the exhaust with that much boost or were you only referring to the other 10psi question?
yep reading skillz own me once agian.
expletive!
yeah 3 inch for turbo exhaust. the greater the presure diffferential accross the turbine better spool time and turbo response. **** run with no DP if you could..
expletive!yeah 3 inch for turbo exhaust. the greater the presure diffferential accross the turbine better spool time and turbo response. **** run with no DP if you could..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude »</TD></TR><TR><TD CLASS="quote">yep reading skillz own me once agian.
expletive!
yeah 3 inch for turbo exhaust. the greater the presure diffferential accross the turbine better spool time and turbo response. **** run with no DP if you could.. </TD></TR></TABLE>
reading owns me while at work!!
expletive!yeah 3 inch for turbo exhaust. the greater the presure diffferential accross the turbine better spool time and turbo response. **** run with no DP if you could.. </TD></TR></TABLE>
2 1/2" or 3" will both be fine for your application. We went from stock to 2 1/2, to 3" then to 4". If you event think you will want to increase power in the future go with the 3".
Steve Sr.
Steve Sr.
Blazeone
Jun 12, 2003 03:17 PM
