Skank2 Intake Manifold for Boost?
Old Oct 23, 2005 | 04:02 PM
BB6-213's Avatar
Default Skank2 Intake Manifold for Boost?
I have herad so much **** about this IM, that it robs power in fi apps, or it makes alot of power in fi apps, now does someone have PROOF or some dynos? Because I am sick of tryind to get thes stupid sheetmetal intake to work properly and I want to look at my other options. Also, is there room for porting in the Skunk2 to get more volume, thanks.
Old Oct 23, 2005 | 04:22 PM
mgags7's Avatar
that mani is too small for FI applications.....yes there is room to port it but why??
what is going wrong with the sheetmetal??
Old Oct 23, 2005 | 04:32 PM
BB6-213's Avatar
too much trouble, vac leaks, no provisions for sesors, throttle cable, tons of stuff, i want something simple.
Old Oct 23, 2005 | 04:33 PM
BB6-213's Avatar
I will put it on later, but I need to get the car started and running good first.
Old Oct 23, 2005 | 04:43 PM
mgags7's Avatar
then just use the oem for now...i see no reason to spend money on a temporary im
what brand is your mani??
Old Oct 23, 2005 | 05:25 PM
BB6-213's Avatar
venom, I prolly will just throw on the stockie.
Old Oct 23, 2005 | 05:28 PM
mgags7's Avatar
you should give venom an earful for that...thats bs
i hear the obx one isnt too bad of manufacture....and theyre cheap...
Old Oct 23, 2005 | 05:51 PM
st3alth's Avatar
what about an Euro-R IM for F.I?
Old Oct 23, 2005 | 05:57 PM
mgags7's Avatar
same deal...not big enough for big fi stuff...
Old Oct 23, 2005 | 09:04 PM
zexifiedlude's Avatar
then what is big enough for fi
Old Oct 24, 2005 | 05:26 AM
st3alth's Avatar
just a modified standard IM + TB?
Old Oct 24, 2005 | 05:40 AM
irocdaparty85's Avatar
Default Re: (jspech22)
I don't know if anyone has looked, but I found Two ludes on here running the SK2 Mani with FI....and both had great results from the install. Both have dynos to prove it.
I have it on my FI Lude...but my stance is somewhat neutral b/c I have no before and after dynos. Also, the other two ludes are up in the 300+hp range, while i'm at the 250 mark.
Old Oct 24, 2005 | 05:55 AM
The Weather Man's Avatar
Well any manifold can make those numbers - you can have those numbers on a stock intake manifold. The thing is, if they change it to a better manifold, and maybe change the TB they could see greater gains.
Old Oct 24, 2005 | 02:54 PM
BB6-213's Avatar
I wish someone had some before and after dynos...
Old Oct 24, 2005 | 04:29 PM
1epmugenlude's Avatar
I have an FI lude running the skunk2 manifold and dont seem to have any problems. Yet to dyno it..
turboH22Aakkord
Feb 24, 2005 09:38 AM
sloweredcivic
Feb 9, 2005 12:27 PM
JoeB18R
32
Dec 17, 2004 09:56 PM
Travis922
Dec 11, 2004 05:17 PM
sonicSVT
Jan 2, 2003 12:37 PM
