Which way does ECU chip go in?
Old Oct 23, 2005 | 02:32 PM
HamiltonRex's Avatar
Default Which way does ECU chip go in?
I pulled my chip out of my ECU and stupid me forgot which way it goes in?
Anyone know? I dont want to take a chance...
Searched for pics but nothing clear enough. Does the white arrow go towards the front or back? (also side with notch)
-Eric
Old Oct 23, 2005 | 02:51 PM
NJIN BUILDR's Avatar
Default Re: Which way does ECU chip go in? (HamiltonRex)
The notch goes towards the wiring plugs.
Glenn
Old Oct 23, 2005 | 03:04 PM
Default Re: Which way does ECU chip go in? (NJIN BUILDR)
Thanks..
Its in right.. But i still get a solid CEL?
Old Oct 23, 2005 | 04:10 PM
Make sure all the legs are in the holes.Its easy to bend one or put the chip in to far forward or back.
Glenn
Old Oct 23, 2005 | 04:31 PM
Jim Truett's Avatar
Did you ever power it up with the chip in backwards? Do you know for a fact that the chip is good?
Old Oct 23, 2005 | 05:23 PM
Default Re: Which way does ECU chip go in? (Jim Truett)
Yes i powered it up with the chip in backwards (first time i put the ECU in)
and no.. i dont know the chip is good. It was in my OLD ecu when it blew a cap.
I cant find the power cable for my burner to make a new chip
Btw.. This is on a new p28 i just finished chipping. Its fine if i cut J1. It will start with J1 connected and my current chip in.. Just solid cel.
So its eaither a problem with my chipping.. or chip. Is there a way to check if all my solder joins are good on the socket?
Old Oct 23, 2005 | 07:11 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">Yes i powered it up with the chip in backwards (first time i put the ECU in)
That chip is done, throw it away. You will need to burn another.
Vtec140
Oct 3, 2017 02:15 AM
WeB
Engine Management and Tuning
Jan 19, 2010 11:17 AM
Da1spaz247
Mar 19, 2007 07:32 AM
siregcivic
Aug 20, 2005 02:39 AM
Toadfart
Apr 14, 2004 12:03 AM
