cant get car running please help
Old Oct 23, 2005 | 12:26 PM
scrEaMO Kyle's Avatar
Default cant get car running please help
99 gsr integra obd2a
just finished changing the headgasket...got everything wired up correctly but it dies when u give it gas
start the car
it idles at like 1,000
surges between 1200-1000-800 rpm really lightly
give the car gas and it will rev up but only when you barely give it throttle
when u go to give the car full throttle the car dies completely
what the hell?
Old Oct 23, 2005 | 01:32 PM
jason13's Avatar
Default Re: cant get car running please help (scrEaMOdc2)
check your vacuum lines, maybe it could be that some may not be connected properly.there is also a oneway valve in the vaccum line coming from the brake booster that would make your car act the same way if it isnt in or pointing in the wrong direction.
Old Oct 23, 2005 | 01:38 PM
can u explain a little better for me what u are talking about?
Old Oct 23, 2005 | 03:29 PM
checked lines....switched map and tps sensors and it wouldnt start so i switched em back and it started but it wont idle for ****
Iloveyourhonda92
Apr 29, 2016 03:11 PM
cb7tuned
Oct 10, 2009 06:41 PM
scrEaMO Kyle
Oct 24, 2005 10:42 PM
scrEaMO Kyle
scrEaMO Kyle
Oct 23, 2005 07:23 PM
