rear disc swap on my 94 CX hatch
Old Oct 23, 2005 | 11:15 AM
ArtNerd's Avatar
Default rear disc swap on my 94 CX hatch
i have new 15/16 master cylinder, entire rear brakes from Integra, ebrakes etc, what else is needed to do this rear disc swap on my 94 CX hatch, just making sure iu have everything before i start ripping **** apart. Is this pretty much an easy bolt on? any tips
Old Oct 23, 2005 | 11:24 AM
john666's Avatar
Default Re: rear disc swap on my 94 CX hatch (j-D-m)
air gun would make it very easy lol.. i think u use the lca from ur old suspension, have to double check. pretty easy swap o ya break fluid also.
Old Oct 23, 2005 | 11:29 AM
lazie's Avatar
https://honda-tech.com/zerothread?id=820484
Old Oct 23, 2005 | 11:35 AM
ArtNerd's Avatar
Default Re: rear disc swap on my 94 CX hatch (lazie)
Nice thanks guys, the guy i got all the stuff for the swap with also gave me a proportion valve, but it looks like it is the same on that is on the car now- looks exactly like the one in your write up too. Will i need to change that, or can i use the one from the CX brake system?
Old Oct 23, 2005 | 12:59 PM
johnecon2001's Avatar
your porp valve most likely isn't the correct ratio for disc brakes. You need to get a 40/40 one for disc.
Old Oct 23, 2005 | 01:37 PM
10secwantabe's Avatar
The proportion valve is the same on both cars.
Old Oct 23, 2005 | 01:41 PM
ArtNerd's Avatar
Default Re: (10secwantabe)
i actually looked at both of them, the stock CX one, has the exact same things written on it as the new one does, that is why i thought they were the same.
Old Oct 23, 2005 | 01:53 PM
neutron91's Avatar
Default Re: (j-D-m)
your prop. valve should be a 30/30 which means 30% of the braking power is applied to the rear... you could opt for a 40/40 valve which means 40% of the braking power is applied to the rear... the best fit on an eg is a valve from a 90-93 teg... fits just like stock ... its not absolutely necessary but it does help... doesnt make you stop any faster it just balances the braking effect out... after i installed mine i could feel the back pulling down and the front end didnt dive as much
Old Oct 24, 2005 | 05:35 PM
ArtNerd's Avatar
Default Re: rear disc swap on my 94 CX hatch (john666)
so do the stock CX brake lines from the drums bolt right up to the new calipers for the rear discs? or do i have to change or modify any of that>
Old Oct 24, 2005 | 11:16 PM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j-D-m &raquo;</TD></TR><TR><TD CLASS="quote">so do the stock CX brake lines from the drums bolt right up to the new calipers for the rear discs? or do i have to change or modify any of that&gt;</TD></TR></TABLE>
You need to use the rear disc brake lines.
cydinthegreat
Suspension & Brakes
Jul 4, 2012 12:15 AM
prennro
Aug 11, 2004 10:31 AM
cheezoto
12
Oct 1, 2003 03:02 PM
servion
11
Aug 13, 2003 10:34 AM
