both tie rod inner dust boot broken! do i have to remove the whole rack to fix?
Old Oct 23, 2005 | 09:57 AM
THE LORD OF CHAOS's Avatar
Default both tie rod inner dust boot broken! do i have to remove the whole rack to fix?
ok, here is the deal. while changing out the brake pads on my gsr i noticed on both the drivers and passengers side the inner tie rod accorrdian looking dust boots are torn. i am not sure how long they have been like this. also i have noticed that when i go over bumps i get this squeak from the front end. this probably means that i need to replace the inner tie tod balljoint too, so my question is so i have to take off the rack to replace all this ****, and how tough of a job is it to tackle? do you guys have any tutorials/tips on how to do this. thanks
Old Oct 23, 2005 | 10:30 AM
gsrious's Avatar
i'd like to learn too...
Old Oct 23, 2005 | 11:01 AM
92integraVTECgsr's Avatar
Default Re: both tie rod inner dust boot broken! do i have to remove the whole rack to fix? (fistandauntilus
Easy Job. Loosen the ball joint nut, Push the ball joint out with a ball joint remover. Mark where the nut tightens to the tie rod end. Losen that nut. and turn the outer tie rod until it comes off. take of the dust boot, replace dust boot with new one. put new outer tie rod on (turning until its put back in the SAME position as the old one) make sure the nut and the tie rod are tightened as close as possible to the original. and that is it. easy job. get a haynes manual from autozone and that'll tell you all you need to know.
Old Oct 23, 2005 | 11:13 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">Easy Job. Loosen the ball joint nut, Push the ball joint out with a ball joint remover. Mark where the nut tightens to the tie rod end. Losen that nut. and turn the outer tie rod until it comes off. take of the dust boot, replace dust boot with new one. put new outer tie rod on (turning until its put back in the SAME position as the old one) make sure the nut and the tie rod are tightened as close as possible to the original. and that is it. easy job. get a haynes manual from autozone and that'll tell you all you need to know.
are you talking about the outer tie rod attached to wheel assembly? becuase i am talking about the boot (looks kinda like a cv boot) that is on the rack which covers the inner balljoint that is attached to the outer tie rod. thanks.
Old Oct 23, 2005 | 01:15 PM
projectTeG's Avatar
the inner boot is annoying, you have to take the outter tie rod off and pull old boot off, install the new one(going to be a tightfit), regrease and install the outter tie-rod and get a alignment.!
Old Oct 23, 2005 | 02:08 PM
Default Re: (projectTeG)
yes.. the the outer dust seal that goes before the outer tie rod. the outer tie rod must be removed to replace that seal.. no other way around it. sorry.. but it is an easy job.
Old Oct 23, 2005 | 02:18 PM
LAOS's Avatar
do it ur self the fuccin shop charged me 165 for parts and labor damn only if i would of know how to do it earlier u can get the tire rods on ebay for less then 50 bucks i think
Old Oct 23, 2005 | 05:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAOS &raquo;</TD></TR><TR><TD CLASS="quote">do it ur self the fuccin shop charged me 165 for parts and labor damn only if i would of know how to do it earlier u can get the tire rods on ebay for less then 50 bucks i think</TD></TR></TABLE>
i really dont want to have a shop do it, i would like to do it myself if possible, but if i have to take it to a shop i think i will just get all the parts myself for cheap and just have them put them on for me becuase i am cheap....
Old Oct 23, 2005 | 05:33 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
its easy man, u dont need a shop top do it, i just changed mine like last year took about 40 mins
Old Oct 24, 2005 | 08:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one &raquo;</TD></TR><TR><TD CLASS="quote">its easy man, u dont need a shop top do it, i just changed mine like last year took about 40 mins</TD></TR></TABLE>
i am going to start gathering the parts this week, so hopefully i can attempt to tackle it either this weekend or next weekend depending if i get everything together. i will let you guys know how it goes...
oh yea one more thing, does anyone know if the inner tie rods off ebay come with the locking washer included? thanks.
Old Nov 6, 2005 | 10:46 AM
i just wanted to update this post. i finally did the job this weekend. it was a bitch, but not as hard as i thought it would be. it took me like 3-4 hours. the hardest part was wiggling underneath the car to take stuff off, and setting the outer tie rods to the right position. i dont think i set them right, so i guess i will have to go get an alignment this week.
Old Nov 6, 2005 | 11:12 AM
nitrofish420's Avatar
Definately get an alignment, because chances are you didn't thread the outer tie rod end back on to the inner the same amount as it was. That thread is the toe adjustment, and if that's even a thread or two off, your toe will be off.
AMS_
22
Jan 15, 2013 05:13 PM
PolyPill
Jul 20, 2009 02:14 PM
vinuneuro
Suspension & Brakes
Jul 29, 2008 01:57 PM
kroze
Jan 2, 2006 06:20 PM
SVOboy
11
Sep 18, 2005 05:09 PM
