1999 civic hx, what kinda maitnence should I do on it?
Old Oct 23, 2005 | 09:20 AM
vltnolia's Avatar
Default 1999 civic hx, what kinda maitnence should I do on it?
I just bought me a 1999 civic hx. I wanted to know what kinda maitnence I should do on it. It has 90,500 miles and no services has been done on it. I just changed the oil, oil filter, air filter, refilled clutch, brake, and power steering fluid. What else should I do to maintain the car?
Randy T
Old Oct 23, 2005 | 09:26 AM
G2 Speed's Avatar
Default Re: 1999 civic hx, what kinda maitnence should I do on it? (vltnolia)
check spark plugs....
Old Oct 23, 2005 | 09:29 AM
95dxhatch's Avatar
no services done huh? well its about time for a tbelt and water pump along with replaceing all the accessory belts while youre at it. check front/rear brakes to see if they need to be replaced. check suspension components, bushings and such. cv shaft boots for rips. probably replace spark plugs and wires, cap and rotor. good luck any other questions ask
Old Oct 23, 2005 | 10:58 AM
CardDealer's Avatar
Banned
Modified by CardDealer at 3:23 PM 11/16/2006
Old Oct 23, 2005 | 09:37 PM
vltnolia's Avatar
I've just replaced the spark plugs, wires, rotor, cleaned thed cap, and cleaned out the throttle body,
My next step is to flush out the radiator, replace transmission fluid and replace the pcv valve.
Does anybody know where the pcv is located on a 1999 civic hx?
What kinda transmission fluid should I use if I didnt use honda mtf?
Modified by vltnolia at 6:54 AM 10/24/2005
VTPSD
Nov 11, 2013 08:10 AM
black0hatch
Honda Civic (2006 - 2015)
16
May 18, 2008 08:44 PM
KrazyDawg
Mar 18, 2008 04:39 PM
Bbasso
Nov 3, 2003 04:27 PM
