Out of ideas (VTEC and VSS CELs)
Old Oct 23, 2005 | 08:49 AM
93CX's Avatar
Default Out of ideas (VTEC and VSS CELs)
Okay, so a few months ago I swapped out my old GSR motor for a fresh B16A2 swap and since then I havent gotten VTEC to work once. Right now I have codes 17 and 21, VSS and VTEC solenoid.
I have replaced the VSS three times and the VTEC solenoid twice, both with known working parts. Same codes.
HOWEVER - my speedometer didnt work before I swapped out the VSS, now it does work, but same code. I've tripple checked all the wiring. Oil level is optimal.
CEL for Solenoid comes on when I get into VTEC rpms and clears every time I recycle the ignition. The VSS CEL comes on only when I drive for a long time on the highway. I've asked all my friends, they have no idea what could be wrong. I even took it to my honda mechanic, he spent two weeks with it, he has no idea.
I'm completly out of ideas.. I've searched the hell out of the archives and found nothing useful. Anyone have any fresh ideas? TIA
Old Oct 23, 2005 | 11:10 AM
93CX's Avatar
Default Re: Out of ideas (93CX)
bump.. VSS seems to stop functioning when it rains out, but all the seals and everything have been checked five times over.. does this point to the wiring being the issue?
Old Oct 23, 2005 | 11:38 AM
hatchi's Avatar
why not try to wire them up directly to the ecu?? there might be a cut somewhere in your harness
Old Oct 23, 2005 | 11:53 AM
93CX's Avatar
Default Re: Out of ideas (hatchi)
But if it was a wiring issue wouldnt the CEL be on all the time and not when I hit vtec rpms? BTW my VSS CEL only comes up when I check the codes, doesnt actually come up very often when I'm driving but it has once or twice.
Old Oct 23, 2005 | 02:43 PM
93CX's Avatar
Old Oct 23, 2005 | 03:40 PM
sicones's Avatar
"replace with a know good ecu" helms baby
Old Oct 24, 2005 | 06:40 AM
93CX's Avatar
Default Re: Out of ideas (sicones)
I'd try that, but there isnt another obd1 p30 within at least 200 miles of me. Any other ideas?
Old Oct 24, 2005 | 08:44 AM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CX &raquo;</TD></TR><TR><TD CLASS="quote">But if it was a wiring issue wouldnt the CEL be on all the time and not when I hit vtec rpms? BTW my VSS CEL only comes up when I check the codes, doesnt actually come up very often when I'm driving but it has once or twice.</TD></TR></TABLE>
Wiring issues don't have to be obvious or easy to find. Your problem sounds like either a flakey ground problem or some intermittent connection between the sensors and the ECU.
replace the main ground wires first, then run the sensor wires directly to the ECU one by one. You will find the problem eventually.
Old Oct 24, 2005 | 10:05 AM
93CX's Avatar
Default Re: Out of ideas (Relic1)
Okay, I was reluctant to do ^^ that for some reason, but I will try it later tonight. Thanks for the input guys..
swindian1991
Apr 3, 2011 09:54 PM
tthoj
26
Feb 4, 2010 04:41 AM
PnkRokCountryboy
16
Aug 7, 2007 11:31 AM
92accordh22a
Dec 21, 2006 07:18 PM
ch00dlz
11
Jun 7, 2006 05:19 AM
