trailing arm torx bolts
i searched and couldnt find anything on the torx bolts for the rear trailing arms to get the drums/rotors off of the trailing arm, is there a trick to getting em off? i tried last night for like 2 hours and didnt get anywhere
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecpoweredsol »</TD></TR><TR><TD CLASS="quote">i searched and couldnt find anything on the torx bolts for the rear trailing arms to get the drums/rotors off of the trailing arm, is there a trick to getting em off? i tried last night for like 2 hours and didnt get anywhere </TD></TR></TABLE>
I tried removing the hubs from a spare set of TAs last night, but those damn torx things are ****. I have the correct sized driver for it, sprayed the **** out of it with pb blaster, and still nothing. A 14mm socket should fit also, but both of mine are busted. (NOTE: They are snapon and I broke them both with a 12" rachet and one arm. Snapon is garbage...)
EDIT: NM. I just checked the the damn thing is round on the outside.
Modified by transpar_nt at 7:13 PM 10/23/2005
Read this thread... Especially JasonGhostz's post! -- You have to heat the torx bolts up. Good luck man
Ooopps here's the tread
https://honda-tech.com/zerothread?id=1403956
Modified by SE7EN3S at 2:37 AM 10/24/2005
https://honda-tech.com/zerothread?id=1403956Modified by SE7EN3S at 2:37 AM 10/24/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one »</TD></TR><TR><TD CLASS="quote">maybe use an impact driver with a torx bit</TD></TR></TABLE>
Yeah, I think I'll have a go at it with my impact tomorrow. That plus 5lb hammer = t3h w1n!!1! (I hope...)
cehcivic15
14
Jun 18, 2012 12:50 PM
speedpro92
Dec 22, 2010 08:17 AM
stripes777
Aug 11, 2008 07:50 PM
Built B16A
May 26, 2006 11:58 AM
wdskuk
11
Jul 6, 2004 11:08 AM
