Grinding noise on VTEC
Old Oct 23, 2005 | 06:30 AM
zeth_an's Avatar
Default Grinding noise on VTEC
Hey guys, I just installed a new clutch and TODA flywheel on my DC2R, and after I run them in, it's making this grinding noise (metal against metal)on and off whenever the revs dropped or changing gears on vtec.
The flywheel is new, it's not a machined fly or used. Any ideas on wat to check or anyone have this kinda experience ?
Any kinda help or ideas would b appreciated
Cheers
Old Oct 23, 2005 | 06:50 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Grinding noise on VTEC (zeth_an)
It sounds like the clutch may be slipping some. Does the clutch need a break-in period? Did you wipe all surfaces free of oil?
Old Oct 23, 2005 | 07:29 AM
zeth_an's Avatar
Default Re: Grinding noise on VTEC (Dogginator)
Yes i break the clutch in for more than 500kms
and the surface is free of oil
Old Oct 23, 2005 | 08:01 AM
Dogginator's Avatar
Daisy... Daisy...
Does this sound subside if you ease off of the throttle?
Old Oct 23, 2005 | 08:54 AM
John Z's Avatar
how were the pilot and throw out bearings?
Old Oct 23, 2005 | 09:11 AM
LUCKY CHARMS's Avatar
i have no experiance of the toda clutch, but i do know some orc clutch kits make a noise when the clutch is pressed or in low rpm, sounds like a bell being dragged under the car
maybe the toda is the same??
Old Oct 23, 2005 | 09:27 AM
zeth_an's Avatar
Default Re: Grinding noise on VTEC (KISS ME LUCKY CHARMS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Does this sound subside if you ease off of the throttle?</TD></TR></TABLE>
the sound only occur when I ease off the throttle after vtec and it comes on and off. during acceleration or driving below vtec, no noise occur.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yaz &raquo;</TD></TR><TR><TD CLASS="quote">how were the pilot and throw out bearings?</TD></TR></TABLE>
both bearings are new
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KISS ME LUCKY CHARMS &raquo;</TD></TR><TR><TD CLASS="quote">i have no experiance of the toda clutch, but i do know some orc clutch kits make a noise when the clutch is pressed or in low rpm, sounds like a bell being dragged under the car
maybe the toda is the same??</TD></TR></TABLE>
Sorry forgot to mention abt the cluthc. It's an Exedy Full face Organic
Old Oct 23, 2005 | 09:42 AM
i've just got rid of an exedy 6 puc kit that one did'nt make any noise,but my nephew has an ORC full face kit & at first we thought there was something wrong with it, now he actually likes the noise 'cause it sounds a bit WRC, is it possible yours is the same, is the clutch letting you down or is it doing the business?
Old Oct 23, 2005 | 05:20 PM
zeth_an's Avatar
I'm not sure wat wrc clutches sounds like or what those clutch kit sounds like
but yea my clutch is doing its business just that i want that noise to go away everytime i hit vtec and slow down
Old Oct 23, 2005 | 05:34 PM
-tc-'s Avatar
that is the same exact set-up i got, doesn't make any weird noises or anything, i know my tranny made a similar noise just before it went out
Old Oct 23, 2005 | 07:11 PM
John Z's Avatar
oh, reason i asked is maybe the pilot bearing didnt seat correctly into the flywheel?
Old Oct 23, 2005 | 09:57 PM
zeth_an's Avatar
Default Re: Grinding noise on VTEC (Yaz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trc_R &raquo;</TD></TR><TR><TD CLASS="quote">that is the same exact set-up i got, doesn't make any weird noises or anything, i know my tranny made a similar noise just before it went out </TD></TR></TABLE>
Ah ic, well now i know for sure lightened fly won't make some crazy grinding noise after vtec Thnx for letting me know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yaz &raquo;</TD></TR><TR><TD CLASS="quote">oh, reason i asked is maybe the pilot bearing didnt seat correctly into the flywheel?</TD></TR></TABLE>
We checked the pilot bearing b4 we mount the flywheel, and last time we checked it was seating properly. But deffinitely will keep that in mind as I'm bringing my car back to my mechanic this friday. Thnx for the input
Old Oct 23, 2005 | 10:14 PM
Ideal R's Avatar
New User
I installed Exedy FW, stage 1 clutch and JDM FD recently and noticed some werid noise when I ease off the throttle or downshift at higher than normal RPM. But those noise are not grinding noise though. I haven't finish breaking in my clutch yet, so I will try to do more testing later.
I dropped a new OEM air filter along with the stock intake resonator at the same time, maybe that's what cause the change of sound in my case.
Please keep me posted, I am very interested to see what you mechanic will say. I might need to go back to my mechanic as well.
suje
Oct 27, 2011 02:28 PM
mr.si1
Oct 19, 2006 09:50 PM
J-g-D-s-M-r
Aug 28, 2003 05:27 AM
Buckshot
Nov 6, 2002 05:29 PM
Black R
Aug 15, 2002 11:47 AM
