MSD coil = car won't start (searched)
Old Oct 22, 2005 | 06:10 PM
jumpman83's Avatar
Default MSD coil = car won't start (searched)
So after searching I can predict that the answer will be go back to stock, the stock one is great. But, before I listen to the advice I know I'm already going to get, could someone confirm that it's not the fault of my installation? Wiring goes: black OEM wire to a new black wire to negative of coil, blue wire OEM wire to clear wire which shares a disconnect on the resistor with the red wire, which is spliced to the OEM yellow wire. The white wire goes from the other side of the resistor to the positive of the coil. Here are the pictures and a wiring diagram to help show where each wire is coming from:
Old Oct 22, 2005 | 06:20 PM
JODYG35950's Avatar
Default Re: MSD coil = car won't start (jumpman83)
your black/yellow is your 12 volt switched wire whick is coil positive through resistor. Your coild negative is a white wire inside the distributor that runs from the old coil down to the ignitor. The blue wire is your tach wire for the ecu.
Old Oct 22, 2005 | 07:51 PM
jumpman83's Avatar
Default Re: MSD coil = car won't start (JODYG35950)
could that white wire be this yellow one? So I just switch the black and yellow wires?
Modified by jumpman83 at 9:01 PM 10/22/2005
Old Oct 23, 2005 | 03:24 PM
jumpman83's Avatar
apearantly not, I switched the wires and it still didn't do anything. I put the OEM one back on, started fine
Silver.007
Oct 12, 2005 06:50 AM
BodyKits NW
Aug 9, 2003 12:38 PM
H22Si
May 28, 2003 10:45 AM
dirtySOHC's
May 22, 2003 07:15 PM
