JDM B18C, which ecu to run??
Old Mar 6, 2002 | 07:39 PM
EKen9's Avatar
Default JDM B18C, which ecu to run??
I have a JDM B18C swap that I am putting in my 98 Civic hatch but I dont know what ecu to run. Should I sell my JDM p72 and get a USDM one? What wiring harness do I need? A OBDII to OBDI?
Old Mar 6, 2002 | 07:57 PM
fowler!'s Avatar
Default Re: JDM B18C, which ecu to run?? (VTECivic2K)
Get an 96-98 Civic EX wiring harness.
Run a USDM 96-98 GSR ecu...or, get a converter harness and run a chipped OBD 1 P28
http://www.jspectuning.com/6gen/
[Modified by Fowler Yo!, 8:59 PM 3/6/2002]
Old Mar 6, 2002 | 09:19 PM
ahcjar103's Avatar
Default Re: JDM B18C, which ecu to run?? (Fowler Yo!)
the jdm p72 has a s*itty fuel curve. do exactly what fowler says.
Old Mar 7, 2002 | 11:57 AM
EKen9's Avatar
Thanks for the help fowler, do you know where I can get a ecu and wiring harness for a good price?
Old Mar 7, 2002 | 12:27 PM
fowler!'s Avatar
You can get a converter harness from Skunk2 or JDMhondaparts.com..
The ecu, you should be able to find on thepartstrader.com. Just be wary of the person you buy it from. Local meetings are better than sending out your cash.
Old Mar 7, 2002 | 02:41 PM
dohcsideSi's Avatar
what about the vtec press switch not being on the jdm motor? my friend has a jdm gsr and can't get the vtec to work w/o the jdm comp, he's used the p 72 and p73, and then he bought the skunk 2 obd1 harness and used a chiped p28 and obd1 gsr no luck. the only comp that ever worked was a jdm comp which the guy that was trying to sell it to him didn't even know what it was !!! idk i'm going to swap the whole spool valve to us spec hopefully that will work
ITRICED
Mar 13, 2008 04:39 PM
GsRated
Sep 26, 2006 05:14 AM
B18C 00 Si
Aug 1, 2003 08:21 PM
willyboyK20
Feb 20, 2002 10:40 AM
Sucka Free
Jan 16, 2002 09:08 AM
