H23 turbo question (searched)
Old Oct 21, 2005 | 03:33 PM
thegeorge613's Avatar
Default H23 turbo question (searched)
I was wondering, the H23 is closed deck (I think, correct me if I'm mistaken), relatively forced induction friendly compression ratio (9.8:1, correct me if I'm mistaken), right. This combo seems good for forced induction. However, from what I've heard on this forum, you can only boost 6-8 psi. Why can't you boost a bit more on a stock block?
Old Oct 21, 2005 | 05:06 PM
The_Head's Avatar
Default Re: H23 turbo question (thegeorge613)
Piston ringlands?
Old Oct 21, 2005 | 06:07 PM
Default Re: H23 turbo question (The_Head)
Any way to fix this weak link?
Old Oct 21, 2005 | 08:02 PM
flip1199's Avatar
either get a good conservative tune or sleeve it and put in forged pistons.
Old Oct 21, 2005 | 08:22 PM
jaywoodz's Avatar
Default Re: H23 turbo question (flip1199)
sleeeve it, I am successfully running 11lbs of boost daily, on my h23, and its running great, no problems at all
-jaywoodz-
Old Nov 1, 2005 | 08:09 PM
whtprelude_96's Avatar
Default Re: H23 turbo question (jaywoodz)
I have been looking to turbo charge my h23 and a lot of the kits I find are for h22's, will a kit for an h22 work on my h23? This is the first honda I have owned so I am not familiar with what works with what yet. Any info or advice on what kits and where to get them would be great.
Old Nov 1, 2005 | 08:12 PM
flip1199's Avatar
Default Re: H23 turbo question (whtprelude_96)
there's plenty of kits for the h23. drag, maxrev, f-max, revhard. but the h22 kit wont fit the h23 because the mani has a different bolt pattern.
Old Nov 2, 2005 | 04:32 PM
what kind of horse power and torque can I expect if I turbo charge a stock h23 and run 7-8psi of boost, I have been hearing thats a pretty safe psi to run for this motor.
Old Nov 6, 2005 | 09:05 PM
Nikoli's Avatar
i have a fully built h23 for sale if your interested........pm me
stpierredm
Jun 18, 2006 12:15 PM
Recon
Nov 25, 2004 11:54 PM
ChaosUnbound
Jan 5, 2004 06:19 AM
Regulator
Jan 9, 2003 09:39 AM
