how to rewire a 3 wire iac?? (searched)
Old Oct 21, 2005 | 12:37 PM
Ls-Turbo's Avatar
Default how to rewire a 3 wire iac?? (searched)
i have an h23 vtec with a euro r manifold i was wondering how to rewire the 3 wire iac?? ne one have ne digrams ?? searched..
Old Oct 21, 2005 | 02:47 PM
prelittlelude's Avatar
Default Re: how to rewire a 3 wire iac?? (Ls-Turbo)
yeah i tried to figure that out too, your probably not going to find the info .. best bet is to make an adapter plate for you stock 2 wire
Old Oct 23, 2005 | 09:59 PM
Ls-Turbo's Avatar
Default Re: how to rewire a 3 wire iac?? (prelittlelude)
bump..
Old Oct 24, 2005 | 02:52 PM
im telling you unless you run the euro r ecu that has the code to control the 3 wire iac then i don't think it can be done with a normal 2 wire iac ECU. this is why most people make a adapter plate to run the 2 wire iac.
Old Oct 24, 2005 | 10:30 PM
Ls-Turbo's Avatar
ic..
Old Oct 25, 2005 | 04:38 AM
kulrevon's Avatar
blacktrax.net has an adaptor plate for the 2 wire on the euro r manifold. just in case you didnt want to make your own.
CMCivicSI
Mar 31, 2009 12:26 PM
antivic
Jul 21, 2008 05:27 PM
mr. carpenter
10
May 6, 2004 09:11 AM
