gsr swap
Old Oct 21, 2005 | 12:21 PM
ekb16's Avatar
Default gsr swap
i just finished my wireing for my gsr in my ek and i have 3 sensors that doesnt plug up to anything, is that correct or am i missing somethin. i layed out my stock civic harness and matched them up with the sensrs on the gsr harness and labled them all.
Old Oct 21, 2005 | 01:03 PM
Tippyman's Avatar
Default Re: gsr swap (ekb16)
pics of da plugs?
Old Oct 21, 2005 | 08:36 PM
ekb16's Avatar
Default Re: gsr swap (Tippyman98)
Old Oct 21, 2005 | 09:16 PM
SirRevvs's Avatar
Do you have any CEL's? Does it start up and run good? I know on my GSR into EJ swap I had 2 plugs left over. One was the thing that goes on top of the I/M, and I don't remeber what the other one was for. Sorry I can't help out more.
Old Oct 21, 2005 | 09:31 PM
ekb16's Avatar
i havent put it in my car yet..i wanted to do all my wireing b4 i drop it in...so far everythin i can see is already plugged up...the only thing i havent wired up is the IAB, VTEC, KNOCK, VTEC PRESSURE
Old Oct 22, 2005 | 01:40 PM
sirb18a's Avatar
what year of engine? and you are using a obd2 harness, correct?
Old Oct 22, 2005 | 01:42 PM
ekb16's Avatar
its a 97 jdm gsr b18C and im using my stock 98 civic harness.
Old Oct 22, 2005 | 02:10 PM
95turboeg's Avatar
one might be crank angle sensor? since it is obd 2..
Old Oct 22, 2005 | 02:30 PM
ekb16's Avatar
ya thats wut someone told me but i cant seem to find the plug for it..when i unplugged the integra harness i didnt catch or see the crank angle sensor that is said to be behind the crank pully. do i have to take off the timing belt cover?
Old Oct 22, 2005 | 02:58 PM
sshonda2004's Avatar
Default Re: (ekb16)
take off the timing belt cover then you should be straight.
Old Oct 22, 2005 | 08:18 PM
hatchi's Avatar
Default Re: (ekb16)
This is what a crank angle sensor looks like
Old Oct 22, 2005 | 08:36 PM
Luserkid's Avatar
Default Re: (hatchi)
Those pics of the plugs dont tell use anything. You need to show us the colors of the wire.
Old Oct 22, 2005 | 11:28 PM
CTRwannaB's Avatar
Default Re: (Luserkid)
just to let u know...since it's a "jdm" motor ...they don't come with cfk/ crank sensors
when u install it u will get a cel...unless u go obd1
and yea that is the cfk sensor...or sensor thingy that checks the crank speed etc..
Old Oct 23, 2005 | 01:58 PM
ekb16's Avatar
ok i checked the wireing diagram in the helms manual and 1 of the senor is the Crankshaft SPeed Fluctuation sensor and the other 2 is the EVAP Purge Control Solenoid and the EVAP Canister Vent shut off valve...so i guess now i have to get a CFK sensor...i found where the EVAP Canister Shutoff Valve is but i cant find where the other EVAP constrol Solenoid Valve goes to...there is only 1 plug on the EVAP canister and that is where the Shut off Valve goes to...
deguzmanEG
Jul 1, 2012 12:46 PM
ssmtyper
17
Nov 21, 2011 02:58 PM
usdmEkb18c1
Jan 14, 2010 12:08 PM
s2k4life2861
Feb 9, 2007 06:14 AM
eknorcal
Nov 14, 2005 10:23 PM
