check engine light with push on gas
Old Oct 21, 2005 | 08:03 AM
sexyblack93lude's Avatar
Default check engine light with push on gas
my car is running like **** the check engine light comes on when i push on the gas, so i cant really check the code, any tips or help would be very appreciateed
Old Oct 21, 2005 | 08:12 AM
accord-lude's Avatar
Default Re: check engine light with push on gas (sexyblack93lude)
check the code and let us know.
Old Oct 21, 2005 | 08:44 AM
kulrevon's Avatar
Default Re: check engine light with push on gas (accord-lude)
you can check the stored code even if the mil isnt still on.
If your ecu isnt storing codes then you have more problems. like blown fuse or wireing.
The Weather Man's Avatar
HA! You can check the code.
When you jump the ecm - it replys with any code that its had since its been reset i think. It will show. Trust. Just turn the ignition to the on posistion and jump it. Read the code and report back.
It'll probably be a code for the fuel system.....maybe.
Old Oct 21, 2005 | 01:05 PM
Default Re: (TheKingPin)
dont i need to ground a wire or something like that
Old Oct 22, 2005 | 01:32 PM
Default Re: (sexyblack93lude)
checked code got 4 which is crank sensor and got 8 which is top dead center anybody have any ideas on these. and i have a brand new distributor by the way but need advice please
Old Oct 22, 2005 | 02:43 PM
Kwaakku's Avatar
Your distribution is not right.
Old Oct 22, 2005 | 11:11 PM
Default Re: (Kwaakku)
yeah its a pretty new dizzy um im gonna check it with a timing light and see whats up anyt more ideas?
Old Oct 23, 2005 | 10:07 AM
Rus1an's Avatar
check your tire pressure, i had the same prob untill i pumped it to 35psi andshe started right up with cels
Old Oct 23, 2005 | 10:17 AM
kulrevon's Avatar
Default Re: (rus1an)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rus1an &raquo;</TD></TR><TR><TD CLASS="quote">check your tire pressure, i had the same prob untill i pumped it to 35psi andshe started right up with cels </TD></TR></TABLE>
are you kidding me?
Old Oct 24, 2005 | 04:04 PM
Default Re: (kulrevon)
bump for some help
Old Oct 24, 2005 | 04:08 PM
mgags7's Avatar
both of those sensors are inside the distributor, make sure you bought the right one, and that the connector is on it snugly
ek98
Dec 24, 2007 08:21 PM
si 1
Mar 31, 2006 12:35 PM
importdude2000
Jul 17, 2004 12:53 PM
type Gendy
Apr 21, 2003 04:48 PM
