HELP! MAJOR OIL LEAK AFTER REBUILD!
Old Oct 21, 2005 | 02:57 AM
scrEaMO Kyle's Avatar
Default HELP! MAJOR OIL LEAK AFTER REBUILD!
99 gsr obd-2
ok guys check this out....just got my head rebuilt.....back to stock spec, with stock valves etc....
using arp head studs...brand new honda head gasket...new timing belt, water pump etc...
anyways the problem -
we finished putting everything together and then we go to start the car and it wont start....we forgot to do a valve adjustment....so we take the valve cover off and adjust the valves.....then we put everything back together and start the car...car starts fine runs good and then all of the sudden we hear a massive leak comming from the back of the motor....
we look to the back of the motor and oil is spewing out from where the head bolts up to the bottom end so we turn the car off....no oil was leaking out of the front of the gasket......but from the passenger side of the car and the back there was oil leaking everywhere extremely bad..i mean its pouring....what the hell is wrong??!!
we used the correct everything....checked the head for everything.....
we even tourqed the head bolts down properly, in the correct order, and by the correct foot pound
anyone had this problem before? what do i do????
Old Oct 21, 2005 | 05:50 AM
help!
Old Oct 21, 2005 | 06:44 AM
b19coupe's Avatar
Default Re: HELP! MAJOR OIL LEAK AFTER REBUILD! (scrEaMOdc2)
Head gasket on wrong? That's usually the cause of that leak.
Old Oct 21, 2005 | 07:49 AM
JdmB16Eg6's Avatar
65.115.123.226
Default Re: HELP! MAJOR OIL LEAK AFTER REBUILD! (b19coupe)
i hope all that oil didnt go on your driveway, if it did, ouch
Old Oct 21, 2005 | 08:15 AM
Power Rev Racing's Avatar
Default Re: HELP! MAJOR OIL LEAK AFTER REBUILD! (JdmB16Eg6)
Did you use both dowel pins when installing head gasket?
Old Oct 21, 2005 | 08:30 AM
ninor's Avatar
Also what is the correct tq spec for head bolts/studs?
Old Oct 21, 2005 | 08:32 AM
vart's Avatar
haha, make sure u dont have two gaskets on your oil filter...
Old Oct 21, 2005 | 08:38 AM
Default Re: (vart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vart &raquo;</TD></TR><TR><TD CLASS="quote">haha, make sure u dont have two gaskets on your oil filter...</TD></TR></TABLE>
checked and there wasnt...thats the first thing we thought...but after looking at the old filter and noticing the leak is spewing majorly out of where the head and the block meet up haha its not comming where the oil filter is....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninor &raquo;</TD></TR><TR><TD CLASS="quote">Also what is the correct tq spec for head bolts/studs?</TD></TR></TABLE>
65 to 70 ft plds
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Power Rev Racing &raquo;</TD></TR><TR><TD CLASS="quote">Did you use both dowel pins when installing head gasket?</TD></TR></TABLE> yes!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Head gasket on wrong? That's usually the cause of that leak.</TD></TR></TABLE> thats what we are thinking
Old Oct 21, 2005 | 09:31 AM
ninor's Avatar
most likely head gasket installed wrong
Old Oct 21, 2005 | 09:37 AM
PURPLETERROR aka BIGMATT's Avatar
headgasket on wrong
Old Nov 12, 2005 | 09:51 PM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
same here i did a lsvtec set up i had oil leak from the head gasket, change head gasket now its leaking from the back of the block. Can it be the head gasket&gt;?
Old Nov 12, 2005 | 10:18 PM
onlinehost's Avatar
Default Re: (phyz)
maybe if it is a ls/vtec your plug in the bottom may have come out just a thougth
Old Nov 13, 2005 | 01:41 AM
itralex's Avatar
Default Re: (onlinehost)
head gasket upside down
always a brain fart moment
Old Nov 13, 2005 | 07:39 AM
heel_touge's Avatar
Default Re: HELP! MAJOR OIL LEAK AFTER REBUILD! (PURPLETERROR aka BIGMATT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR aka BIGMATT &raquo;</TD></TR><TR><TD CLASS="quote">headgasket on wrong </TD></TR></TABLE>
haha yup just did this EXACT thing. but i remembered the valve adjustment. its leaking out of the teardrop oil passage in the top left corner. the gasket only covers like 1/3 of it.
its upside down. and its also a 50 dollar mistake. but you learn from them
speaking of which, make sure your mating surfaces are CLEAN. i was i n a rush and didn't think to clean the oil of the bottom off the head. now i have to go back and change it AGAIN because there is a green/oil splatter on the driver side shocktower. so my 50 dollar mistake is now a 100 dollar one. lesson learned. TAKE YOUR TIME. MEASURE TWICE CUT ONCE. its really emberrasing, but i figured someone else can learn from the stupid mistakes i made.
Old Nov 13, 2005 | 10:37 AM
WrongWD's Avatar
haha everyone beat me to it. flip the headgasket
Old Nov 13, 2005 | 12:20 PM
i took the head off because i know its the head gasket a friend of mine didnt really clean the block an the head befor he put the new hg . also i notice the old gasket sealer on the new gasket wich that mo fo didnt really clean it good
parton84
Dec 16, 2013 06:36 AM
scrEaMO Kyle
Oct 21, 2005 06:36 PM
lilxvtecxpwr
Dec 7, 2004 07:57 AM
lilxvtecxpwr
10
Dec 7, 2004 06:09 AM
lilxvtecxpwr
Dec 7, 2004 03:49 AM
