Ok this is going to be a real stupid question. re: headgasket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface »</TD></TR><TR><TD CLASS="quote">nm, answered my own ? with a little research. The answer is "No, you idiot."</TD></TR></TABLE>
Your not an idiot. Honda made the headgaskets .5 over from stock so you could use over sized pistons. You were told false information
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmintegraxsi »</TD></TR><TR><TD CLASS="quote">Your not an idiot. Honda made the headgaskets .5 over from stock so you could use over sized pistons. You were told false information
Well, I've got a stock head gasket sitting on my 81.5mm block right now, and there is gasket in the chamfered area of the cylinders.
</TD></TR></TABLE>Well, I've got a stock head gasket sitting on my 81.5mm block right now, and there is gasket in the chamfered area of the cylinders.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">If your head chambers are 81mm then why wouldn't you be able to use a stock head gasket?</TD></TR></TABLE>
Because part of the gasket will be exposed to the combustion chamber. I don't know about you, but the thought of having a thin piece of stainless in there gives me shivers. Hot spots=detonation city.
It should fit. Are you sure it is 81.5mm? If you look on Honda or Acura, they sell oversize pistons but one size headgasket....
i've used an straight-from-honda headgasket, slapped it on an 81.5mm bore motor w/ room to spare, and the motor runs fine
the bore on oem HG's is a little bigger than 81.000000000000 mm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface »</TD></TR><TR><TD CLASS="quote">Because part of the gasket will be exposed to the combustion chamber. I don't know about you, but the thought of having a thin piece of stainless in there gives me shivers. Hot spots=detonation city.</TD></TR></TABLE>
I dont think you understood the point I was trying to make. If you have an 81.5mm bore and a 81mm head. Thats a sharp edge in the combustion chamber too.
