I have a lip in my cylinders, I'm going to be running lower compression, do I need to have it remove
Old Oct 20, 2005 | 08:55 PM
Sinner's Avatar
Default I have a lip in my cylinders, I'm going to be running lower compression, do I need to have it remove
I have a d16z6, i going to get the motor cylinders honed tomorrow. This is my first engine build and I feel an edge where the old pistons landed at the top of the cylinders. Since i'm going lower compression i figured i could just have it honed to remove the glaze and the lip wouldnt matter since the new pistons will not reach that high in the cylinder.
Am I right or wrong?
Nick
Old Oct 21, 2005 | 12:23 AM
Cuda70's Avatar
Default Re: I have a lip in my cylinders, I'm going to be running lower compression, do I need to have it re
Make sure you have that block checked before you start your rebuild. If your fingernail bairly drags the lip and everything mic's out, then you have no problems. It would be best to use a ridge reamer to cut that lip off. I hope you got the cylinders checked before you bought the new pistons.
Modified by Cuda70 at 4:12 AM 10/21/2005
Old Oct 21, 2005 | 08:00 AM
Sinner's Avatar
any more opinions?
wolf95
11
Nov 10, 2009 09:36 AM
ECX
Paint and Body
25
Dec 7, 2007 02:16 PM
sk8shorty012
Feb 6, 2006 06:06 PM
s2kDinesh
Honda S2000
50
Jan 23, 2005 07:02 PM
ej20_chris
Jan 4, 2002 08:09 PM
