Clutch Replacement
Can anyone take the time to give me a step by step through a clutch replacement? If not are there any suggestions? My clutch is going out fast and i can't afford for a shop to fix it. Also any special tools i will need that you could inform me of would be great. Thanks for your help.
you need to consider how you are going to get the transmission out. the only special tools you will need are a torque wrench, something to hold your engine up when the trans is out,12pt sockets, and a big *** socket (1 1/4" I think) for the axle nuts. The rest is standard hand tools. It takes me about 3.5 hours to do this job on a lift including a new flywheel from start to finish. I think you will take all day if you do it in the garage. If you do not have the tools to do it, it is cheaper to take it to a shop. If you mess the job up, it will cost you more time than its worth in dollars.
SantaCruz92Si
33
Aug 12, 2003 01:19 PM
